This is usually caused by a cold water supply problem, since cold water is what is used in the rinse. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlet valve (especially on the cold side). Make sure they are clear of rust and debris. The solenoids can be tested using a mulitmeter or ohmmeter. Test for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. Hope this helped and best wishes.
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Keeping in mind that the soap & bleach gets dispensed into your wash on the
second to last rinse cycle and that most all rinse cycles are in cold
water. Is your cold water valve screen plugged causing your washer to
rinse poorly? Are you using the HE detergent? If not maybe the
washer is sudsing up to much and having a hard time rinsing all the
suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting
does it take a long time to fill the washer up? Also when it is full
and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of
the washer it might have a hard time draining out all of the soap
water before the next load
