Question about Dryers
When I press the start button on my Kenmore Dryer Model #96291100 I hear the motor humming and the timer clicking but it's not turning on. The belt is good
  • 74 Answers
You have a problem with a part called a capacitor,which holds an electric charge to start the motor when,when it's faulty,the motor cannot start,hence the humming noise.it must be replaced,only by a qualified repairman.
Posted on Oct 07, 2009
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
Kenmore dryer model 110.63112100 drum does not turn
Check both of your circuit breakers if the dryer is electric. Though the heating elements are 240v, the motor and electrics are 120v and connect to only 1 side of the plug. The breaker for that side may have tripped.
When you press the start button on the dryer, are you able to hear a motor turning (humming) faintly? If you can, and the drum doesn't turn, this is an indication that the belt has broken, jumped off its track, or the tensioner / idler pulley is either broke or skipped over the belt.
Jul 01, 2010 | Kenmore Dryers
I have a Kenmore dryer model no. 1109282610. When
the motor is humming,could be something stuck in blower wheel,might of had lint filter out and ran dryer and something went down into blower wheel,the belt could be locked up or the motor is bad,take the belt off of motor and see if motor spins
Nov 02, 2009 | Kenmore Dryers
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
131 people viewed this question
Top Dryers Experts
