Question about Kenmore Kitchen Ranges
Adjust oven thermostat on kenmore range 362.73271691
This is an economy model and may not have any adjustment but... can the oven thermostat be calibrated? Set to 350 and only reaches 310. Pull knob off - solid plastic shaft - no set screw. Perhaps press and hold shaft? Don't know.
fridgetech
  • 473 Answers
SOURCE: kenmore gas range
You need to turn the orifice on the safety valve down (clockwise) and this will make the flame smaller. The orifice is what the burner for the oven sits on at the bottom. The valve is # 214 on this diagram. http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0124111&brandID=0582&modelDesc=GAS%20RANGE&modelNumber=3627331890&documentID=10033508&documentTypeID=PLDM&documentClassCode=PM&titleType=BURNER%20SECTION&titleID=00001&. Hope this helps.
Posted on Nov 04, 2007
SOURCE: Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Posted on Jun 02, 2008
  • 161 Answers
SOURCE: oven temp set at 350.
Use an oven thermometer Try to figure out if by setting it to 390 it will maintain 350 accurately. (A 25 degree change while it cycles is normal. It will probably overshoot before going off and undershoot a little before cycling on.) If so the thermostat has just drifted. Pull off the control know and look usually there is an adjustment on the shaft to change the temp showing on the knob. set it up 50 degrees. If the knob can't be changed just know that you have to adjust yourself. If it won't maintain a steady temp the thermostat is bad and will need to be replaced. The thermostat will be over $100 it may not be worth it. If this is a computer controled unit (pushbutton temp selection) the sensor needs to be replaced. This is a lot cheaper than a thermostat.
Posted on Jul 03, 2008
vegakitten20
  • 685 Answers
SOURCE: Range will not hold a consistent temperature
here is a site that might be helpfull http://forums.partselect.com/range-repair/index109.html
Posted on Nov 11, 2008
aborcass
  • 2651 Answers
SOURCE: oven temperature adjustment
well no need to fret, if you oven is heating over 100 degress off theres problably not an adjusatment to compensate for that, youll need to either replace the htermostat or the thermistor, depending on which your machin uses
Posted on Jan 20, 2009
How to calibrate oven?
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
Dec 01, 2016 | Ovens
Why will my kenmore oven only heat to 212 degrees after 2 houres?
Why is the oven temperature incorrect?
The oven temperature control is usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.
Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.
On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.
Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
May 28, 2014 | Kenmore Ovens
Oven is not holding correct temp
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
When you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, and then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Let us know if you want something else please accept the solution.
Jan 02, 2011 | Maytag MGS5770 Gas Kitchen Range
Oven Flame
Hi still under warrenty get who sold this to you to come back and fix it
Feb 21, 2010 | Kenmore 71312 / 71319 Gas Range
Can you adjust the oven temperature probe to a
Please provide the model number for this oven.
Chances are you can adjust the temperature offset form actual, but not the bandwidth.
Dec 18, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
Mar 27, 2009 | Kenmore Ovens
Oven themostat not set correctly
Your thermomitor may be going or the oven sensor could be the problem. Buy a BRAND NEW thermomitor and put it in the middle of the middle rack and set to 350. After the preheat is done, wait another 10 min and read thermomitor with flashlight through door glass. This will be the MOST accurate way. to tell
Mar 26, 2009 | Kenmore Kitchen Ranges
American Range ar6b-24rg
If you oven temp is off by +- 50 degrees, thermostat needed to be change. to check and adjust the oven thermostat usually we place the oven thermometer in the center of the oven, run the oven at 350 degrees for minimum 30 minutes and check the oven temperature, It should be +- 25 degrees, if it needed adjusting, there is the adjusting slot screw in the center of the thermostat stem, to adjusting it ( do not turn thermostat stem during adjusting ), turn adjusting screw counter clockwise to raise the the temp, clockwise to lower the temp, turn it a little at a time and wait 15-30 minutes before do the next adjustment until the temp match with the oven knob. To adjust the oven burner air and gas mixture, first turn the air shutter close, you will see yellow flame, then open the shutter until the yellow flame disappear and them open it a little more, now you are done. For the oven uneven cooking? you may have a bad oven burner tube, during operation some of the flame may be lift off, disappear or flame being uneven, you can check it with the kick panels off to see the flame, if these are the case, you needed to change the oven burner tube,
Feb 04, 2008 | American Range AR-4B-36RG-CL Gas Kitchen...
Kitchen Ranges Logo
302 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
