Question about Canon PowerShot A570 IS Digital Camera
Even with new batteries it says to change the batteries
Why does my camera keep saying battery exhausted even when I change the batteries?
If batteries leaked in the camera the connections IN the camera may be dirty. Putting in a new battery takes care of the battery connection but not the camera connections. This is why it is very important to take out batteries when you are done taking photos. When you want to shoot again you put the batteries back in and set the time and date. You MAY be able to clean the connections with a pencil eraser. If you use a pencil eraser please blow out the dust from the eraser. If you are positive the camera then I cannot help you here.
Jul 20, 2014 | Nikon COOLPIX Cameras
The batteries died while I was taking photos. The lens did not retract. I changed the batteries and it would not come on. Changed the batteries again and got a message 'Change batteries'. I hooked it up to...
I don't know if you have a voltage meter, but you do, check the voltage of the batteries, you just tried. I have seen many "new" batteries that aren't good, and had similar problems as a result.
Even so I'd suggest a brand new set of Duracell or Energizer batteries, BUT.....
Why aren't you using NiMh rechargables?????
They have much more power will give you over a year of picture taking even if you shoot hundreds of pictures a day. All you need to do is make sure you charge them about once a week, even if you don't use the camera.
Sep 07, 2013 | Canon PowerShot SX10 IS Digital Camera
Camera says "change batteries" even with new batteries
Hi, Has anyone resolved this issue yet, I have a powershot s2 IS with the same issue - i replace the batteries with brand new duracell's and it says replace batteries i reseat the batteries and it works for a few pics if im lucky then says replace batteries again - any help would be appreciated - Canon offers no solution.
Oct 13, 2009 | Canon PowerShot A720 IS Digital Camera
How is that possible that even if my computer works with external electicity it turns off? It says that the battery is dying.... I, ve changed three chargers and the problem is still there... is the...
It basically means the battery has outlived it's use and can no longer hold a charge. Even though the charger is hooked up you will still need a new battery to get away from this problem. Once the new battery is installed and charged this error should disappear. Hope this helps.
Sep 19, 2009 | Acer Aspire 5000 Notebook
Change the batteries message even with new NIMH RShack batteries
The solution is to change the small 'date/time' battery. You can have the regular batteries as charged as you like, it won't make any difference. The tiny date/time battery is in the same compartment as the regular batteries, on the opposite side of the hinge. Extract it with a fingernail, it is situated on the left hand wall of the battery compartment (when the camera is inverted and the compartment open).
Jun 12, 2009 | Canon PowerShot S2 IS Digital Camera
When putting in new batteries the "change battery" sign comes on
try new Alkaline batteries or fully charged NiMH batteries, you may need to clean and adjust the springs in the battery compartment
this tips may give you more details
http://www.myfixtips.com/blog/digital-camera/why-my-camera-keeps-saying-%e2%80%98change-battery%e2%80%99-even-with-new-batteries-176.htm
May 14, 2009 | Canon PowerShot A520 Digital Camera
Camera won't work. Only shows Change Batteries,even with new ones
akaline batteries wont work
only rechargable FULLY CHARGED
if that doesnt work clean battery terminal
Apr 28, 2009 | Canon PowerShot A470 Digital Camera
Black Screen; Change Battery Message
simple! with my Canon S90 had the same problem until I changed the SD card from LEXAR for a TOSHIBA SD card and the message " Change the Battery Pack"disappeared.
Jun 27, 2008 | Cameras
Canon A95 "Change Batteries" problem!
I have this problem as well. I thought it was a problem with my NiMH batteries. So, I bought a volt meter to make sure the batteries worked. I have 8 AA NiMH batteries. I charged them all up and tested them with the volt meter. They were all good to go. However, no matter what I put in the camera one of two things happens:
1. I get the "change batteries" message.
2. I don't get the message, but the next time I check the camera (a few days later), one of them is totally drained.
Something is very wrong and I plan on contacting Canon.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
54 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
