Question about Brother HL 2140 Laser Printer
Red Error light is on, what is this error and how to get out of it?
If the light is steady (not flashing), it means a paper problem. Either the paper tray is empty, or maybe the document you're trying to print is set to 'manual feed.' If the latter, then modify the page setup in properties, to use the defult paper tray.
Posted on Oct 18, 2009
Solid red ready light on DELL 2230d printer
The Red light on this printer means one of the things listed below are at fault
The printer is experiencing an error, such as open cover, empty paper, not installed waste toner container, or full waste toner container. • The printer is experiencing a service required error, such as LSU error, fuser error, or ITB error
Aug 14, 2014 | Dell 2230d Laser Printer
My newly installed Samsung CLP-310 has a red light showing next to the <...> icon. Please could you help me to resolve the problem. Thx
Hi paulette,
if the light is red and TONER COLORS LED all LEDs off
• The machine is experiencing an error, such as jammed paper, open cover, empty paper, installed waste toner container, or full waste toner container.
• The machine is experiencing a service required error, such as LSU error, fuser error, or Contact your sales or service representative.
if the light is red and TONER COLORS LED each LED lights red.
• Each toner cartridge is totally exhausted. You can not print.
• Each toner cartridge is wrong.
Aug 01, 2011 | Samsung CLP 300 Laser Printer
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
One flashing red light.
usually with 1 red light errors, there will also be an error that shows on the screen like e73, e74, e75, etc. You will need to first get your secondary error code.
then enter either the e-code from the screen or the secondary error code into the repair guide
Mar 06, 2009 | Microsoft Xbox Console
1 red light
You can check out the informative blog post at http://www.fix-xbox360.info/2008/09/11/xbox-360-disc-read-error-e74-error-no-video-problem/
This post describes the E74 error with one red light problem.
hope it helps...
Jan 04, 2009 | Microsoft Xbox 360 Console
SYSTEM ERROR - E007 SOLUTION 3
when i switch on the machine, it show a red light with the word system error E007
Aug 09, 2008 | Creative Labs Zen Nano Plus MP3 Player
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
One red light bottom right hand corner
hope it helps...
Jul 22, 2008 | Microsoft Xbox 360 Console
An error message comes on screen when thew xbox 360 is turned on as well as it says up the top (system error .contact xbox customer support )also three red lights flash on and off
This is either an error code or the 3 red lights of death. If it is the 3 red lights, and not an error code, you will be under the extended warranty. If it is an error code, hope u are under your origional warranty.
May 09, 2008 | Video Game Consoles & Games
Brother HL 2140 Laser Printer Logo
459 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
