Question about Gaggia Titanium Espresso Machine
Grinder blocked My Gaggia coffee machine displays ' grinder blocked' symbol. I've taken the machine apart and cleaned the grinding mechanisim then replaced it all very carefully. However this has made no difference. Is there any way of fixing it or ordring this part to save on an expensive repair. It's out of warranty help!
  • janebriggs77 Oct 08, 2009
    The grinder has completely stopped and the machine has an electronic display saying 'grinder blocked'
    I've opend up the machine and unscrewed the fitting to clear all the beans out and replaced everything again - however it still says it's blocked
  • bansheracer May 11, 2010
    Hi Does the grinder turn when you push the coffee button?
    President:
  • 1,618 Answers
Check the chute from the grinder to the brew unit.
Posted on Oct 07, 2009
My Gaggia Unica won't grind the coffee beans, it just whirs and stops making the drink
More than likely the machine is stuffed with coffee grind. Need to take it apart and clean it. See https://www.youtube.com/watch?v=JQbP2v8C-sA
Sep 20, 2014 | Gaggia Unica Bean To Cup Coffee Machine
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
Does the gaggia titanium have a grinder sensor? Can anybody tell me where it is? I have the "grinder blocked" message. I've cleaned the grinder, Shute and doser door, but I still have the...
Hi...Grinder blocked message is ..when you make coffee there is no current going into the grinder. In other words the grinder motor is blown(coil windings in the motor is blown). You have to replace the motor. The problem is common with Gaggia, Talea, Odea coffee machines. hope your machine is less than 2 years old to get fix under warranty.
Apr 10, 2012 | Gaggia Titanium Espresso Machine
Hi, The machine is trying to grind beans then states that there are no beans, yet the bean holder is full. We have dismantled the holder and cleaned out the grinder block, it worked once or twice then...
IT could be that the grind is too fine and the grinder is being clogged with coffee, first try adjusting to a coarser grind at least 2 to 3 numbers, if coffee flows into the brew unit you are good to go if not, then grind chamber needs to be vac out and cleaned then adjust grind and start over.
Apr 13, 2011 | Gaggia Titanium Espresso Machine
Display saying GRINDER
my machine does not say grinder block but it saying coffee bean holder is empty when it is full.
Aug 03, 2010 | Gaggia Titanium Espresso Machine
New grind and display shows "grinder blocked"
This normally indicates due to the grinder being set too fine or oily beans being used.
Try setting the grind on 7 .
If it still fails the grinder will need to be unblocked and serviced.
Dec 07, 2009 | Gaggia Titanium Espresso Machine
Hi i have on the screen grinder blocked, i have clean it out and checked the grinder motor its ok. Switch it back on gone to make a drink but come back on the screen grinder blocked. Anybody got any idear...
When you said cleaned it out did you remove the grinder burr gears,vacum out the coffee shute and the coffee dump solenoid?
I do this then put it back together,set the grind on 7 and normally all is good.
Nov 19, 2009 | Gaggia Titanium Espresso Machine
Gaggia machine sounds as if it keeps grinding but no beans are getting through the grinder. I have cleaned machine completely, emptied the beans, opened the grinder to the biggest setting and still no...
The grounds chamber/gate might be blocked you will have to clear it out. Remove brew unit and find discharge for grinder, then push gate back and clean.
Aug 25, 2009 | Gaggia Syncrony Espresso Machine
Gaggia Titanium integrated grinder not spinning, not grinding.
your grinding chamber is blocked, the same happened to me, did it struggle to grind before? try taking the black shoot out the top with the 2 screws( were you would put pre ground coffee in) take the brew unit out(along with the waste water and bean tray), and reach up to where there is a little spring, the spring controls a little door, if you open the door manually and clean out the shoot to the grinder( make sure the machine is unplugged for this), i used the end of a tea spoon and a little hoover. it should work after this
Mar 18, 2009 | Gaggia Titanium Espresso Machine
Gaggia Syncrony does not get past the grind cycle
Water has probably been spilt in the beans area. The grinder needs cleaning out along with the chute
Feb 24, 2008 | Gaggia Syncrony Compact Coffee...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
546 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
