Question about Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door
I can not lit the pilot
I turned off my fireplace in this summer, and now I want to turn on it, but I could not re-lit the pilot following the instruction (put the pilot positiion, and depress it, and push buton button ignitor several times). And i even asked a technisin to look at it, and found that there was no gas fellowing to pilot, and told me he could not solve the problem. Could anyone make suggestion to solve this problem?
  • Napoleon Master
  • 3,239 Answers
It sounds like air in the pilot tube its a very small hole in the pilot and takes ages to come through undo
the pilot tube at the gas valve and see if you have gas coming while depressing the the knob
Posted on Jan 21, 2010
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
How do we fix a remote control for a Direct Vent Fireplace?
check to see if you have a resettable dip swith in the venting system, if you do have one, press it once, it should then come on. also make sure the gas valve is in the on position and not just in the pilot position,. Also after being off all summer season, sometimes a slitgh tap on the gas control is all it needs to dislodge the magnetic pilot plunger.
Oct 01, 2016 | Heating & Cooling
FIREPLACE WILL NOT TURN ON
Yes and no......
If the fireplace wont turn on from that switch, Most likley a diffrent switch
Dec 19, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Turned down the fireplace accidently turned it off. The pilot can be pushed in however it is not igniting . Can it be lit manually
If your getting a flame when igniting, and your still pressing in on the pilot then all you need to do is hold it in for about 30 seconds or so. This is because theres a thermal cutout then needs to heat up form the pilot to keep the flame lit.
If you've got no flame at all then you should look at your fireplace manual and see if theres an alternative to lighting the pilot. I wouldn't recommend opening it to light the pilot.
Apr 17, 2011 | Heating & Cooling
Once I get the pilot light lit , hold for 30 seconds, and the let the knob out to turn to low or high, the pilot light won't stay lit.
From what you're describing, either the Thermocouple needs cleaning or it needs replacing, However, these are not easy units to work on for a Do it your-selfer. so I would recommend taking it in to a pro who can get the part if necessary and replace it if necessary. Most independent hearth stores that sell and service gas logs and gas fireplaces can help you.
Jan 24, 2011 | Endless Summer 233000 Open Flame Patio...
Pilot light has gone out how do i relight it?
Hi .. look at the control valve on the burner .,. there is a knob you can turn. It has markings for pilot and run, or something like that. turn the knob to pilot and push and hold it in. Light the pilot wit a long fireplace match. After the pilot is lit, wait about half a minute and relese the knob,, the lp[ilot should stay lit.
Apr 03, 2010 | Water Heaters
Intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
Jan 02, 2010 | Heating & Cooling
Temco DV6400N fireplace will not turn on. Pilot
Do you have a remote that turns the unit on and off
and has different heat settings? Could be the batteries are bad in remote
My fireplace pilot light can be lit but when I flip the switch to turn the fireplace on and the pilot light blows out
First, and least expensive thing to do is replace the thermocouple. Probably weak.
Hope this helps.
Nov 18, 2009 | Ovens
Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Dec 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Logo
352 people viewed this question
Top Napoleon Pool & Spa Experts
John Rodgers
John Rodgers
Craig Butler
Craig Butler
Paul Carew
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
