Question about Toshiba TDP-SP1 DLP Projector
I keep getting a no pc signal even though I'm connected.
It has worked in the past, even though it sometimes meant shutting down my computer and rebooting. Now, even that doesn't work.
  • 2,237 Answers
If you get no power, you'll need to replace the power supply. if you are just not getting a signal, reset the settings to factory default on the projector and replace the cable.
Posted on Nov 11, 2009
My tv, smart tv keeps shutting off during the setup procedures, won't get past the wireless connection search. Searches for wireless connection but shuts off before one is found.
The TV is shutting down because it is getting no signal from the selected input, so it turns itself off, it is not a problem it is deigned that way,.
Nov 11, 2016 | Televison & Video
Toshiba sattelite a665 keeps shutting down
Hello i think you have a overheating problem.
The problem can be solved by cleaning the cooling element that cools down the cpu.
Its probably blocked by dirt.
I do sometimes have luck cleaning it with compressed air but you should BE CAREFULL not to harm the mainboard.
I do sometimes also remove the cooling element and give the cpu new cooling paste.
If you not have tried that before it should be a task for a computer repair guy.
Good luck
Sep 09, 2012 | Toshiba Computers & Internet
My computer shut off by itself even though the battery was charged and the battery light kept blinking even after my computer was off. computer seems hotter than usual on bottom as well
It is probably shutting down to prevent thermal damage dut to overheating. Check that the fan is working. Even if it is, if the vents are clogged with dust the machine will not be able to cool properly. The only real remedy is to open the case, clean all the vents and fan, remove the heatsink, clean off old thermal paste and apply new paste before replacing the heatsink and putting back together.
Mar 14, 2012 | Sony VAIO VGN-S580B (VGNS580B03) PC...
I installed a new battery into my HP G60 233NR. However sometimes when i power on my computer i get a black screen. Sumtimes after sitting for awhile it will boot. Other times I have to unplug the battery,...
I have a G62 that I've taken apart a couple times to fix issues. Right now the video card has an issue with turning on. I can get it to work by turning the brightness down before I shut it down; it will boot normally usually. If not, I can flip the screen open and closed a few times and it will finally get going. It's a backlight powerup problem that I haven't the patience to sort out. The battery has nothing to do with it, except it diddles the voltage a bit and might get the display working. I can't see the bootup screen, though; if I want to change anything, I have to connect an external monitor.
I usually blow the dust out of it with an air compressor every few months (I use it rarely). Otherwise the heat sink and fan cruds up with dirt and overheats.
I like the PC even though it's 6 years old. It runs all distros of Linux nicely. Mint, openSuSE, Ubuntu, Bodhi, Puppy, Manjaro.
Apr 06, 2017 | HQRP Computers & Internet
The computer shuts down after 10 to 30 min..I have already change the fan.
When computers shut down like this they are getting the signal from the motherboard. This is most likely a thermal shutdown signal from the processor. When you changed the fan, did you clean the processor off and apply a small thin layer of thermal paste? The processor may not be cooling properly or the motherboard is getting a bad signal from the processor's thermal circuit. Try new thermal paste on the processor and then go through the board again and make sure everything is in its place. Also, leave the side panel off and see if the system stays running, this will aid in the cooling. Let us know if it works, if not we may have more ideas to help.
Aug 25, 2010 | Computers & Internet
The router is running fine all hook ups are fine changed the wireless card took that to a computer place and it was running fine at the shop when I got the pc home unable to access the internet even though...
The cable internet is not "seeing" the computer. The router is blocking it. That is why it works if you plug it into the modem directly. How to solve this is to turn everything off and unplug power to modems and routers for 3-5 minutes. Then replug in routers. Then restart computers.
That is why it worked at the computer store. Everything was shut down and restarted.
Also, sometimes it is necessary to call the ISP (for example Comcast) and have them re-send the signal. Also going to Control Panel Network Connections and choose "repair the connection" will reset the signal.
Be patient it will work.
Aug 15, 2009 | NetGear RangeMax WPN824 Wireless Router...
Wireless issues with my Dell XPS/Dimension One desktop
Even if it's a new Dell, you may need to update either the drivers for the wireless card or the BIOS.
Also, verify which protocol your Dell is set to use (i.e. 802.11g, 802.11b, auto-select, etc.). Dell may have fixed to to a slower protocol for compatibility.
May 02, 2009 | Dell XPS One Desktop
DVI no input signal......VGA input active.
Are you running an additional Video card? Or are you using the built in one.
You might try cleaning the connector / plugs with acetone from finger polish remover or de=natured alcohol.
Never jam anything on a computer.
If its an add on card, remove it and reboot. Shut down and reinstall card and reboot.
keep me posted please,
Feb 22, 2009 | HP dx2300 Monitor Personal computer Intel...
I keep losing my signal intermittently on my Belkin MIMO plus wireless router it constantly goes up and down from 1.0 Mbps to 54.0 Mbps interferring with my connection. The router is connected to my...
your gonna need the belkin router amplifier for that if its too far away from the router its gonna loose signal and cause you to intermittinly loose signal and connection ./... you could also contact belkin support at www.belkin.com/support
Jul 19, 2008 | Belkin Computers & Internet
Laptop shutting down
A quick fix is to blow back into the vents to blow dust out.
May need to dismantle though and clean fan and maybe even remove heatsink and renew thermal paste.
Jan 06, 2008 | Computers & Internet
Toshiba TDP-SP1 DLP Projector Logo
122 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
