Question about NetGear WGR614 Wireless Router
I am trying to install a Netgear WGR614v9 router. Disk will not install it, so tried a manual install. Shut down all firewalls, used no passwords or security settings. It keeps throwing me back to the Dynamic IP box time after time.
    Genius:
  • 1,269 Answers
The router needs to be configured manually. Follow the steps below.
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing). Or password is admin also.
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing). Or password is admin as well.
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Posted on Oct 06, 2009
I have netgear wgr614v9. how can i login router?
1) Open up your internet browser (Internet Explorer, Firefox, etc)
2) Navigate to: http://192.168.0.1 or http://192.168.1.1 (try both of them)
3) Login name: Admin, password: password or use this: Login: *blank*, Password: Password.
Mar 30, 2011 | NetGear WGR614 Wireless Router
I JUST MOVED AND NEED HELP HOW TO RESET MY NETGEAR WGR614V9 WIRELESS ROUTER. WHAT DO I DO TO RESET MY PASSWORD TOO I THINK. thank you
Turn the router over and check the defaults on the bottom of the router. try the default admin and password to see if you can gain access to the router. Most people use the defaults so this might be a good way of gaining access. Otherwise there is usually a reset switch on the back or front of the router. You wil need a paper-clip[ to reset the switch. then you can use the defaults to gain access and reconfigure the router.
Jan 14, 2011 | NetGear WGR614 Wireless Router
Recently we had WIFI installed in our business. The pass code is a huge alpha numeric number that is rediculous for us to give our customers for internet access. How can i change this passcode?
You'll have to log-in to the wireless router. If it is an off-the-shelf router you can consult the documentation or use a search engine to find out the default username and password for the router. For example, if you have, say, a Netgear WGR614v9, you would Google "default username and password for Netgear WGR614v9" You will also need to know what to type into your web browser, such as http://www.routerlogin.net (for a Netgear).
However, if someone set the router up for you, they most likely and should have changed the password if not also the username. You may have to call them to find out that info. If the ISP installed the router, call them.
Once signed-in to the router look for something like "wireless settings" or similar. Then just change the passphrase.
Be advised that making the passphrase shorter or easy to remember jeopardizes your network security. If you have any valuable data on your network you shouldn't be letting customers on it without taking precautions.
Jan 13, 2011 | Computers & Internet
Can not reset router , netgear wgr614v9 user name
Hello
First unplug router.Then hold reset button in for 30 seconds,button is usually in the back may need a pen tip or paper clip to hold it in.
Then plug back in.Try logging on using admin as username and password as password.
Nov 02, 2010 | NetGear Computers & Internet
1 year old Toshiba Laptop will not connect to NETGEAR wgr614v9
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 12, 2010 | NetGear WGR614 Wireless Router
I have a netgear router WGR614v9 . I forgot its password. I can not connect any computer to internet. How do i reset the password?
There should be a reset button at the back of your Netgear router. Press it for 10-30 seconds and that should reset it back to factory settings.
Cheers!
Angel
Jul 08, 2010 | NetGear WGR614 Wireless Router
Trying to connect netgear wgr614v9 router to new toshiba computer with windows 7 ....setup says unsupported operating system....what do I do
As netgear setup disc doesnot support Win 7.
U need to manually setup the netgear product
-- hard resett the router using a restore factory setting hole on the back of the router
-- open the netgear router page using www.routerlogin.com
-- Username - admin , Password - password
-- run setup wizard
-- if it detects dynamic ip then press next
-- and on the left u will see wireless settings under setup .
-- secure the network using WPA_PSK(TKIP)
-- and then apply .
In case if it will detect static or fixed ip .
Then click on " Basic settings "
-- Under router MAC address
-- select "use computers MAC adress "
-- Apply
-- And then Powercycle the network..
-- And u will be able to go online ..
Jan 02, 2010 | NetGear WGR614 Wireless Router
I need a manual for the wgr614v9, where can I download it from?
Dear Williams,
Here is the Manual for WGR614v9 , you can download it, from this site:
http://kbserver.netgear.com/products/WGR614v9.asp
Be Happy Always
Regards
Dec 09, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
4,791 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
