KitchenAid 325 Watts K5SS Heavy Duty Commercial Stand Mixer
Problem for KitchenAid 325 Watts K5SS Heavy Duty Commercial Stand...
My kitchenaid mixer was stored
By lanie5511 on Oct 06, 2009
my kitchenaid mixer was stored on its side and leaked oil. I don't dare use it now. Can I replace the oil myself? There are no mixer repair centers anywhere near me.
Solution #1
posted on Oct 11, 2009
Not Rated)
lilhelper
Rank: Guru  KitchenAid Expert
Rating: 97%, 47 votes
your oil leaking is cause by a bad gasket or the gasket isn't seated properly. you can purchase this gasket but replacing it does require knowledge of the unit. part number for the gasket is 4162324. the grease can be purchased locally at any car parts dealer. generally a thicker paste type grease is used inside these units, but the original part number for the grease is 4160588 and comes in a container with enough grease for 5-8 mixers.hope this helps
Thanks
Was this helpful?
Yes
No
Popular Solutions for KitchenAid 325 Watts K5SS
Questions and Unsolved Problems for KitchenAid 325 Watts K5SS
Do you recommend KitchenAid 325 Watts K5SS Heavy Duty Commercial Stand Mixer?
Answer
Answer
I am having problems with my k5ss kitchenaid mixer. The problem happens when i tryed to even mix... (More)
Answer
KEHC309JSS05 door shows open. indicator says ''close door''. The door IS closed. New oven, been in... (More)
Answer
K5A 30 year old mixer will only operate at lowest five speeds. stays at speed 5 as control is moved... (More)
Answer
My KitchenAid mixer does not turn off. I'm sure it has something to do with the switch which does... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For KitchenAid 325 Watts K5SS...:
Top Mixer Experts
Rank: Guru Guru
Solutions: 2519
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Mixer Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
