Question about Olympus Stylus 830 Digital Camera
When I take pictures no matter what I change the settings to or if I leave it on auto they still come out grainy, blurry & with red eye. Could the sd card be the problem
SOURCE: Cannon Powershot SD 870
you can change it to no flash by when your taking a picture press the right arrow
Posted on Jul 19, 2008
  • 225 Answers
SOURCE: kodak EasyShare C743 takes blurry picktures
If your lens has a jammed focus motor, you will have to replace the whole lens unit.
Posted on Nov 17, 2008
  • 172 Answers
SOURCE: panasonic lumix dmc-tz3
The TZ series is not known for good indoor pictures. T Z is short fot Travel Zoom. The is great for outdoor pictures and long distance shots.
Indoors, be sure you use flash and your subject is within 8 feet so flash light can reach them. Let the camera select the proper settings using the Intelligent ISO setting.. Or set it to Night slow shutter speed) while holding the camera, and subject very still for 3 seconds after shutter press, and with Image Stabilization on.
Also, don't forget if you are viewing the pics on your big screen PC, then the pics will always look worse than they will either on your Camera screen professionally printed pix fo 5x7, which will likely be fine to acceptable. If you get up to 9x10 printed sizes, then you will likely see what you would see on a large PC screen....not very good.
There is a chance you have a bad camera. If it is under warranty, take it to a panasonic repair center locally. I am afraid if you send it off to a depot, they may charge you while declaring nothing is wrong with it.
Posted on Feb 27, 2009
michaelpasch
SOURCE: The night setting results in blurry pictures
The grain is from underxexposure and the blur is from hand shake caused by low shutter speed. Try using a tripod. Also, change from auto settings and shoot in manual mode with a high ISO and low aperture setting. Good luck!
Posted on Jul 15, 2009
  • 4090 Answers
SOURCE: grainy pictures...iso problem for olympus stylus 820
Without ISO you will not be able to take pictures.
ISO is the old ASA which is related to film speed
ISO 50 is very slow film speed and may result in blur and some grainy appearance , same as if you PUSHED ISO up to 800 in low light.
Try setting it to ISO 100 and see if that helps.
You can still select auto, but its related to either shutter or aperture priority in relation to the set film speed ( now ISO 100)
Posted on Sep 10, 2009
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
Hello! I actually have a TZ3 and have been having problems with the quality of the pictures without using the zoom (grainy) as well as problems with the quality of the picture when using the zoom...
Hello, yes a few suggestions "grainy" could be from an auto ISO setting the sensor speed high as in possibly ISO 400 even 800 or higher you get the pictures but it's grainy. On pocket point and shooters this is most often the case in full automatic modes and on your camera it's called "Intelligent ISO Mode" You should consult your manual and select a more user selectable ISO speed manually. Another feature with your camera is image stabilization this you can turn on or off preferably off when the camera is mounted to a tripod. Okay for the blurry part on the zoom the quickest way to explain this is every tiny movement you make holding the camera is magnified 10 times, this is where the image stabilizing feature would be handy. Jennifer in my younger days I could hold a 35mm camera with a 300mm lens steady at 1/60 of a second now I use only a 200mm lens with image stabilization "on" to get the same results. What you have is a full time auto everything camera if it's working for you it doesn't matter if it's 3.5 years old. You are still working with a 7.2meg camera with a print capability of 11x14. hope this answered some of your questions.
Dec 28, 2010 | Panasonic Lumix DMC-TZ2 Digital Camera
Pictures are all grainy and blurry. At first all pictures were great but now they are all out of focus and grainy. I don't think any settings were changed but am not sure.
Most likely causes:
The camera was dropped or damaged.
Flash is turned off when it is needed.
Lens is dirty.
ISO setting set to high.
Best bet is to take it to a camera store and let a professional check it out.
If this helps please vote for my solution.
Nov 27, 2009 | Nikon COOLPIX L20 Digital Camera
Blurry pics
Go into the setup menu and scroll to "reset" and follow the on-screen instructions. Sometimes that will restore your camera to original specs.
Oct 07, 2009 | Olympus Stylus 790SW Digital Camera
Jul 15, 2009 | Nikon COOLPIX S200 Digital Camera
Grainy pictures at night
Hi
Low light without a flash will always cause grainy pictures unless you have a very high end camera that can shoot at very high ISO speeds like 6400 and up.
Try changing the camera from the green camera 'auto' setting to "P" and then press the Menu button (I think it's Menu) and look for the different mode settings. There should be one for Night or Night Portrait or similar, I can't recall Sony terms and I don't have one here to check sorry.
Your other option is to use the flash, try it with Red Eye turned on if possible.
Hope this helps.
Thomas D.
Owner, Darntoothysam com
Nov 03, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Pictures come out very grainy
Most likely, you've set the ISO value higher than necessary for most circumstances. You may have done this deliberately to catch some fast action, or you accidentally hit the ISO button without realizing it. If you reset to lower ISO settings, your graininess problem will probably disappear.
The faster the "film speed", whether you're using real film or a digital camera, the more grainy the pictures will be. ISO is the film speed. The ISO speed is set by pressing the ISO button (just above the "FUNC SET" button); it cycles thru AUTO, HI, 80,100, 200, 400, 800, 1600, then back to AUTO. If you've set the camera to AUTO on the control wheel opn the top of the camera, then you can only select ISO of AUTO or HI (which is slightly faster than AUTO).
The higher ISO settings are useful in low light conditions or to catch fast action, but those higher settings should not be used otherwise because of the increased graininess.
I hope this helps you.
Oct 19, 2008 | Canon PowerShot A540 Digital Camera
Blurry pics indoors
1. you could try it with flash, but the lighting in the picture would look artificial, won?t reflect the interior of the building as it really is, and the flash will cover only near objects leaving the rest dark, and we?ll be missing the point. 2. recommended ? place the camera on a stable platform(table, chair, shelf etc in lack of a tripod), adjust its vertical angle by placing some flat object under the front side of the camera, set it to auto or a preference to slow shutter speed(usually 1/60 to 0.5 of a sec according to the lighting), set timer(most cameras only give you about 2 seconds) in order to avoid vibrations during the picture taking. 3. you should avoid using more then 50 to 100 ISO, more will give you a grainy effect. You are promised a sharp picture with life like colors that looks real.
Feb 21, 2006 | MitekMedia CD30P3 Digital Camera
Olympus Stylus 830 Digital Camera Logo
26 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
