I have an IP camera on my network. I tried to access it from a different PC then I usually use. The camera only works in IE, it uses ActiveX to view the video. When I tried to open the web site I got a error 400 code. I tested it and it opens fine in firefox on the same PC, but unfortunatly I can't view the video. I am using IE 8. Thanks in advance, Jim
  • 81 Answers
U can first try >
Go to control panel> find internet options> go to the advanced tab> click on RESET > then chk>
if not go to add or remove programs> go to view installed updates> uninstall IE8> it will rollback to IE7
Posted on Oct 07, 2009
Connecting wireless cam with different ip address
An IP camera is a video camera that can be viewed over a Local Area Network or the Internet. The camera typically is monitored locally from a computer via the network to which the camera is attached. With just a few additional configurations of your network, you can access the IP Network Camera so that it can be monitored remotely using the Internet. This is the benefit of a network camera, as it can reside on an IP network and the video stream can be accessed or saved remotely.
Get the Default Gateway of your IP. Do this by entering "ipconfig/all" in your Command Prompt and hitting "Enter" on your keyboard. Your IP information will be brought up, and number you are looking for is the Default Gateway. This is underneath the IP address. Identify this number by its number pattern, which will look like the following: 111.222.3.4. Access your router. This is done by simply typing the default gateway from Step 1 above into the address bar of your Internet browser, and pressing "Enter." Forward your port by configuring your camera. Open the configuration section on the router web page where port forwarding is located by clicking on the "Applications & Gaming" link along the top of the page. In this menu, click on "Port Range Forwarding." Configuration sections can be located differently with each kind of router. Find this information by referring to the documentation that came with your router when you purchased it. Access your camera over the Internet. To do this, type your public IP address into the address bar of the web browser and press "Enter" in the same way as described in Step 2 when entering your default gateway. Note: The public IP address is different from your regular IP address. The regular IP address identifies computers and other devices on your network, whereas your public IP address is what is used to make yourself known to others on the Internet. Your Internet service provider can supply you with your public IP address if you call them and ask for it.
Viewing an IP Network Camera over the Internet http://www.networkcamerareviews.com/articles/portforwarding.html
Apr 18, 2013 | ASI Trendnet Wireless Tew-639Gr 300Mbps...
How to connect an ip camera with a different ip address
Apr 18, 2013 | Computers & Internet
I do i get the default username and password for vivotek fd8134 camera
Get the Default Gateway of your IP. step 2 Do this by entering "ipconfig/all" in your Command Prompt and hitting "Enter" on your keyboard. Your IP information will be brought up, and number you are looking for is the Default Gateway. This is underneath the IP address. Identify this number by its number pattern, which will look like the following: 111.222.3.4. Access your router. This is done by simply typing the default gateway from Step 1 above into the address bar of your Internet browser, and pressing "Enter." Forward your port by configuring your camera. Open the configuration section on the router web page where port forwarding is located by clicking on the "Applications & Gaming" link along the top of the page. In this menu, click on "Port Range Forwarding." Configuration sections can be located differently with each kind of router. Find this information by referring to the documentation that came with your router when you purchased it. Access your camera over the Internet. To do this, type your public IP address into the address bar of the web browser and press "Enter" in the same way as described in Step 2 when entering your default gateway. Note: The public IP address is different from your regular IP address. The regular IP address identifies computers and other devices on your network, whereas your public IP address is what is used to make yours lf known to others on the Internet. Your Internet service provider can supply you with your public IP address if you call them and ask for it. Hope it helps.
Jan 23, 2013 | Vivotek FD8134 - Network camera - dome -...
Trying to port forward requests to the IK-WB21A webcam. From inside the house it works great. From outside, port forwarding port 8001 to 80 and I get NO response. Tried tcpdump and there is no response...
What are you using to view the Camera? Is this the only IP camera you are viewing/.accessing on the network? If it is not, are you using different IPs in the non-DHCP pool.
Typically you do not have to set-up port forwarding to gain access to the camera within the network. Normally port forwarding is set-up when you are outside your network and need to gain access to different applications/devices in your network using the same static IP address.
Let say you have a camera ip on 192.168.1.20.
You can connect to the camera with your web browser inside your network with the IP 192.168.1.20 (obviously), but if you have the camera set up to only be triggered on a specific port (other than the browser's default 80) let's say 100, then you would enter 192.168.1.20:100.
If the only thing on your network is the camera that you want to access from outside. you would setup in your router to route all incoming requests from port 80 (which is the web browser default) to the IP of the camera. Sometimes routers ask for a range just enter 80 to 80.
If the camera is working on a different port like 8001 then you would port forward 8001 to 8001 to IP 192.168.1.20. You would enter in your web browser (off-site) your static IP 69.132.54.176:8001. But I would suggest if the camera is the only thing you will be trying to gain remote access to, then leave it at 80 and set up forwarding for port 80 to the IP.
That way you can set up a free DNS service and not worry about paying extra for a static.
Nov 13, 2009 | Home Security
Cannot login to configure Belkin SMB KVM-over-IP swith
This happened to me until I installed the activeX control. Were you prompted for that, and did it install successfully?
After the activeX installed, did it also prompt you to install the secure certificate to access the site without IE prompting about invalid certificates?
Since you've tried multiple machines, I doubt security settings on IE are causing the problem. But my switch did these two actions before I was able to login successfully.
Jan 30, 2009 | Computers & Internet
No picture when using IP address on Internet Explorer
After you log in their should be a config screen.
Suppert can be found in Panasonics FTP server.
1000's of apps and manual for this camera and more.
ftp://ftp.panasonic.com/pub/Panasonic/cctv/downloads/
Aug 28, 2008 | Panasonic BL-C1 Network Camera
Logging onto my personal IP address
"HTTP Error 403 Forbidden" indicates a server permission error. You need to allow either anon access to the IP camera. You can probably do this using a local PC connected to the SAME subnetted network that your IP Camera is on.
Jul 17, 2008 | RIM BlackBerry 8800 Smartphone
Can't access my DSC 950G security camera
you have to log into the main IP address, not the camera IP address. If you are using wireless, the camera will have an IP address different than the one for the router coming from the ISP.
I just bought this camera myself and am trying to work out the kinks. My ip keeps changing and i am not sure how to keep it the same, static?
Jun 02, 2008 | Black Box IP Address Translator With...
Can't view image using Internet Explorer 7 with Window Vista Business.
Once IP camera setup complete access can be done with any browser regardless of operating system. So even if its on Vista, XP or Linux it will be accessible. For example if Camera IP has been set as 192.168.0.33, You need to type http://192.168.0.33 in your browser (IE 7 will work).
If you dont have user manual you can get from the link below
ftp://download.level1.info/manual/WCS-2010(EN).pdf
If you need further assistance please post your question
Good Luck
Jan 31, 2008 | Levelone WCS-2010 Network Camera
Viewing software
The WV-NP244 camera requires an ActiveX Plugin. Microsoft Internet Explorer for Mac does NOT properly support ActiveX.
The specs for the WV-NP244 state that you must use a Windows PC with Internet Explorer.
You may want to try Boot Camp, or other dual boot/Virtual software emulation software to be able to run Microsoft Windows.
Jan 23, 2008 | Panasonic Wv NP244 MPEG4 & Jpeg Compatible...
Computers & Internet Logo
David Payne
David Payne
