Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
How do I get the front of the vacuum off to change the belt?
    President:
  • 389 Answers
Go to www.dysonmedic.com
Scroll to the bottom of the page and you will find a link to an illustrated guide.  Excellent!
Posted on Oct 07, 2009
HOW DO I CHANGE BELT ?
Hello! Below are step-by-step instructions for changing the belt on your Hoover S1147.
1. Rotate nozzle to the vertical position. Lift off front cover.
2. Remove the two bottom plate screws.
3. Pivot off bottom plate making sure to unhook center tab on inside edge of nozzle.
4. Remove agitator and used belt from nozzle.
5. Put new belt on agitator. Position agitator in nozzle orienting agitator end caps with slots on both sides of nozzle. The belt should line up with tab on inside of nozzle.
6. Attach belt to motor pulley.
7. Replace bottom place by first hooking it to center tab on inside of nozzle.
8. Reposition screws and front cover.
Hope this helps!
Jun 02, 2014 | Hoover S1147 Twist Vac Handheld Vacuum
Eureka whirlwind+
It's a little tricky but here's how you get to the belt:
  1. Once you have removed the housing and the roller, turn the vacuum so that you are facing the pin the turns.
  2. Pull the belt to the back of the unit with your right hand so that the belt is against the pin on the front side and with your left foot apply pressure to the carriage where the roller sits. This action causes the plastic housing next to the pin to move toward the front of the vacuum providing enough space to slide the belt off easily.
  3. Be careful that you do not apply too much pressure with the foot.
May 02, 2012 | Eureka Altima Upright Vacuum Model 2996AVS...
How do I change the belt on my Hoover U6311-930?
At the front 2 screws hold on the front cover if you remove them you will be able to access the brush roll and belt
Feb 27, 2011 | Hoover U6311-930 Power Drive Bagged...
How do I change the belt on my Kirby sweeper?
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off)
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again. This releases the tension on the belt
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate and you can access the belt.
You can get a replacement belt here:
Kirby Ultimate G Replacement Belt
Oct 28, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How do I change the belt on my vacuum
Turn the carpet head upside down and look for visible screws at the front edge of the bottom plate. Inspect for others further back .Once removed the plate should hinge forward and separate from the base.
Clean burned rubber from motor shaft and spin brush roll when replacing belt to check for wobble or hair and fibre wound in to ends of brush.
Sep 05, 2009 | Vacuums
I cannot find how to get bottm plate off to replace sweeper belt. where do you change the belt?
There are 3 screws on the top housing, one on the front Right, Front Left and behind the hose in the back
Aug 29, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
Jun 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka whirlwinde litespeed vacuum - model 5841
very simple under all three screws in the front (two on sides and one in back) once open--you can take off that panel...take brush out...take old belt out...put new belt on..around brush..place both inside...and make sure belt is around that little pole thing towards the back close panel, replace screws
Mar 22, 2008 | Eureka WhirlWind Litespeed 5844 Upright...
Kirby heritage 2 sweeper
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
the above link shows you how to change the belt on the g-series kirbys but it will apply to the heritage edition as well...the only difference is the color...some of the arrows may be missing on the front belt lifter knob...but they are little differences...
hope this helps!!!
Feb 06, 2008 | Kirby Heritage II Vacuum
How to change belt on Eureka Whirlwind
On the top cover, there are holes at the front on both sides, there is a screw on each side in one of the holes. Take the out, and the cover should come off, then you can get to the brush roll and belt.
Dec 27, 2007 | Eureka WhirlWind 4381 Upright Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
41 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
