Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
I have a Chamberlain garage door opener, Series CG40, 1/2 HP, #41A5021-1F. It opens just fine using the opener located on the wall. However, when I try to use the remote it does not work. I have installed a new battery. When I follow the directions on the back of the motor to program the remote, the light blinks like it is programmed but it still won't work. Thank you for any help you can give me. Bart Birkeland bartb@gwtc.net
    President:
  • 3,197 Answers
Try programming this way. Hold the button down on your remote and then press and immediately release the smart/learn button. If this doesn't do it your remote may be bad. The wall control is hard wired and doesn't use the receiver that your remote does.
Posted on Oct 14, 2009
The wired keypad (Chamberlain) of my garage door is not working. The red light on the keypad keeps blinking. Can someone tell me how to fix that? FYI, the garage opener, the remote, and the wall unit all...
You can try programming the keypad using the procedure below.
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Mar 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Hello i have a Chamberlain LiftMaster Professional 3240 Opener 1/2 hp the lights work but motor does not come on when i try to use the wall door opener does the unit have a fuse or somthing? because i...
There is no fuse in this opener. It sounds like you have a bad wall switch if the motor runs when you use your hand remotes. Maybe a little more information will help.
Aug 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have an old craftsman 1/2 hp door opener. It
You may have a bad wall control. Try disconnecting it from the opener and try. Otherwise it is time for a new model.
Apr 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
IChmberlain Garage door does not pen or close
The light flashing 5 times is the code for "RPM sensor or motor overload" and the 10 clicks sounds like the relay for the main light bulb that flashes when the door sensors are blocked or misaligned.
If you want an owners manual and have Adobe Reader you can go here and get one.
http://www.chamgerlain-diy.com/pdfdocs/A2490M.PDF
Oct 15, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp door opener
replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 16, 2007 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
456 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
richie46
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
