WHERE DOES THE TONER GO, ON THE OKIDATA FAX MACHINE?
  • 2 more comments
  • awcarwls Oct 06, 2009
    the fax machine keeps asking me "from location" what does it mean what key should i press. I need help.
  • awcarwls Oct 07, 2009
    i want to purchase some toner for the okifax 5050. I'd like to know how much and how soon it will be before I can recieve it also how to install in into the machine, I also need a manual.
    thank you
    allison
  • awcarwls Oct 09, 2009
    i need toner.
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    On the paper
    President:
  • 3,085 Answers
Oki c5550 INCOMPATIBLE YELLOW
Are you using factory or aftermarket toner?
Jan 07, 2014 | Oki Electric Industry Okidata C5550n MFP...
Como resetar drum da Okidata MB480
Trate esto:
REPONGA de OKIDATA TONER BATERIA.
Encienda maquina al empujar y teniendo los DOS botones de men? de arriba/abajo en mismo tiempo.
2. La ventana del menu mostrara "OKI USUARIO"
3. Desplace a "el Modo de Dialogo de Motor" es indicado. El empujon Entra boton.
4. "Xx diagn?stico de Modo. xx. el S-MODO de xx es indicado.
5. Desplace al inicial de NV-RAM es indicado. El empujon ENTRA.
6. La ventana muestra "NV-RAM- Inicial Pospone 1".
7. Empuje EN LINEA y ENTRE Botones simultaneamente y el ASIDERO por 10 segundos despues usted ve "Ejecutar
Repuso" parece en la ventana de menu.
8. Reinicie impresora.
Todo el toner, la bateria, las figuras de fuser y transferencia vuelven a 100%.
Permita que sepa si esto ayuda.
Jul 19, 2011 | Oki Electric Industry Okidata MB 480 ...
Indication is INK TONER WASTE BOX FULL Not sure what to do, if any thing? Al
You need to replace the waste toner collection bottle. The waste toner bottle has to be replaced every 30,000 Letter pages on average. Order part number 42869401. The directions will come with the replacement unit. Remove and dispose of the old waste toner carefully.
Manuals for the C9600 series printers are available from OkiData: http://my.okidata.com/PP-C9600hdn.nsf?opendatabase . You can order the waste toner bottle for $14 from OKI here: http://esales.okidata.com/IWCatProductPage.process?Merchant_Id=1&Section_Id=5001&pcount=1&Product_Id=1102864 . Other online vendors have the part as well.
I hope this helps.
Jun 30, 2011 | OKI C9600hdn Laser Printer
Fatal error : 144 on a Okidata
this is indicated when the toner feed switch error
or the toner locklever-open error occurs repeatedly when new toner is used.
it has to do with the yellow.
3 possible solutions.
Confirm that the lever is in position.
Replace the toner feed unit.
Replace the ID units.
Aug 28, 2009 | OKI C9600hdn Laser Printer
B4600, "Install Toner, Toner Missing" Error
I had a customer with that problem and the issue was the toner cartridge. If you take it out of the photoconductor unit and look on the end there should be a metal connector tab. If you look on the left side of the photo unit you will see metallic contact points that need to connect to the metal tab. Oki has several toners that will physically fit in the B4600 but they have to be the ones with the metal tab to work right or you get the error. The correct toner part numbers are: 43502301 or 43502001
Check your toner for the tab is that is not the problem, get back with me and we can go from there.
Buddy
Corporate Computer
www.ccl-la.com
Aug 07, 2009 | OKI B4600n Printer
Replaced toner, machine continues to say toner
Aug 04, 2009 | Brother IntelliFax-2820 Laser Fax
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Jul 03, 2009 | Brother FAX-2920 Plain Paper Laser
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
My fax machine doesn't print fax
Do you have a full toner cartridge in the machine. The fax will not print if it thinks that doesn't have any toner
May 03, 2007 | Brother IntelliFax-2820 Laser Fax
26 people viewed this question
jasbo
jasbo
