Question about Breville Die Cast 800ESXL Espresso Machine
My breville espresso machine is leaking at the top where the steaming arm connects to the unit. Do you know why this is?
    President:
  • 1,618 Answers
The o-ring /gasket in there might be worn out.
Posted on Oct 07, 2009
Water is leaking from my Breville Barista Express Espresso machine's water tank valve.
u r is the 4th problem with the same unit. take it bak to the store and git another 1.
Feb 23, 2015 | Breville The Barista Express BES860XL Open...
My breville bes870xl filter light won't stop flashing single and double. I've unplugged the unit and plugged it back in and turned it on and it still continues to do this.
PDF]Getting to know your machine - Breville
https://www.brevilleusa.com/media/.../BES860XL.pdf
Translate this page
rested coffee beans produce espresso with much more taste .... filter size you select, and along with the GRIND. AMOUNT dial ...... create steam. When the steam lightstops flashing it is ready .... cappuccino machines is purchased. THE RIGHT ...
Dec 07, 2013 | Breville Coffee Makers & Espresso Machines
Steam building up within the unit/
The steam pipe after the steam solenoid to the steam arm is leaking which it can be cause just becase the support nut is loose. So if you just remove the top plastic panel you can even use the machine and see which point need to tight it up.
Good luck.
Remember top vote for this answer
Mar 10, 2010 | Saeco Royal Professional Espresso Machine
Extremely loud squealing noise during steaming milk
This could be blocked. The best way to clear this is to switch off the machine and see if you can dismantle the frother arm. Sometimes the arm will come off by unscrewing. If it does, wash it in hot water and washing liquid. If it doesn't come off try putting the frother wand into a mug of cold water and allow it just to steam the water.
Frother wands don't just steam liquids - they **** up liquid which can block the vents and the actual steam hole which this machines' problem sounds like it does have.
Apr 05, 2009 | Breville ESP8XL Espresso Machine
No rubber fitting on steam arm
The rubber fitting does 2 things. It splits the steam and it keeps the end from bumping too hard. You don't need it but make sure you clean the steam tube well.
Jan 25, 2009 | Breville ESP8XL Espresso Machine
Rubber fitting for steam arm
You really don't need it. You should have a cloth nearby to clean the wand when you're done. So if for some reason you need to move the wand (and with it's meagre rang of mobility I don't know why you would) be sure to grab it with the cloth because it gets really hot. The rubber thing is just there to avoid lawsuits I'm sure.  USA USA!
Not making steam
hi tried99X. couple of possibilities: have you made sure steam wand is completely clean? allowed adequate time for water to heat? try looking inside: unplug machine, remove the ten screws on the bottom and gently lift away base: it does have wires connecting it to rest of machine so be carefull not to yank on them. locate the hose leading from the pump to the steam-arm (may be hard to see; use a good penlight and a small telescoping mirror if you have to; Autozone & other auto parts stores sell them for a couple of bucks-if you don't want to take off the entire casing of the machine. does the hose look okay?) also see if the pump has vibrated out of position. also, when's the last time you descaled? good luck!
Dec 07, 2008 | Breville ESP8XL Espresso Machine
Chrome on steam wand wearing off
Posted by compliance12@embarqmail.com
I have a Breville Die Cast 800ESXL and due to wrong cleaning process, I have to buy the steam wand. I tryed to find them in Breville.com but they does not have this part available for sale. Where can I buy this Steam Wand for my Breville Die Cast 800ESXL.
PLease let me know ASAP, at compliance12@embarqmail.com
Thanks
Oct 12, 2008 | Breville Die Cast 800ESXL Espresso Machine
No steam or pump noise
get a used starbucks barista by saeco for a couple hundred...you'll be pleased. (know i am-and i only paid $25 for my year old breville esp8xl POS). verify it works-it will probably last longer & perform better. if inclined/capable, maybe you can replace the pump yourself (a new one's prob in $35-$40 range; if more, scrap the machine or sell it "as is" for parts & put the money toward a better machine. good luck!
Oct 07, 2008 | Breville ESP8XL Espresso Machine
Breville espresso machine 800 ES
I have the same problem. It appears to be caused by a worn steam wand gasket that's inside the steam wand assembly which can be unscrewed from the Breville machine. This was confirmed by the folks at Breville. They referred me to www.thegourmetdepotco.com. That website does not sell the steam wand gasket separately. They sell "Frother Assembly MOdel #800ESXL-250" for $14.95. With tax ($1.42) and shipping via USPS ($5.65), the total is $22.02. A very high price for the failure of a simple plastic washer, but it beats buying a new machine!
Greg
Feb 24, 2008 | Breville Die Cast 800ESXL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
493 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
