Question about Digi Televison & Video
My digifusion fvrt100 stuck on hold and has been for 3 months it is running on a 12v 3.3amp power cable and it's out of warrantly
  • 3 Answers
Hi. I had a similar problem, but cured it by getting a new PSU with a larger rating 4A. The digibox is now perfect, and earlier problems of lockups were also fixed. I suspect the original PSU wasn't really man enough for the job.
The new PSU (originally for flat screens) cost £9.99 incl postage from Ebay, from the seller AC Adapter Specialists. Delivery was prompt. Type is 12V 4A tft lcd screen monitor ac adapter. Check the DC outlet plug matches your digibox.
Posted on Oct 30, 2009
RE:Panasonic-5137 TV. Is the only way to use DC by using internal batteries or can one attach via the AC adapter port a car battery or a 12v/3amp power source? Thanks
I don't know that TV but I assume it is battery operated. Most portable electronics allow for external power supply. Check your manual for required power supply at check for power port on TV housing. There should be label vhat is required voltage.
Mar 09, 2018 | VIA Computers & Internet
Need a power supply for mr Maxtor Hard Drive 120 GB SN Y3LCM1EE 12v & 3 Amp.
Go to tiger direct or new egg for the best prices. Make sure that the power ratings on the new one is the same or higher than the old one.
Oct 13, 2014 | Maxtor Hard Drive
Change hovearound battery?
1. Disconnect joystick cable.
2. Remove seat.
3. Undo straps on battery covers.
4. Disconnect batteries.
5. Remove batteries.
MPV 5 requires 2ea 12V, up to 35 ah agm or gel batteries. (The ah will vary depending on the brand of battery used). My personal preference is Werker batteries (12V, 35ah agm) at Batteries Plus. If you can get the chair there, they will install them for you and give you a 1 year warranty which is 6 months longer than most.
May 18, 2014 | NRS Hoveround MPV 5 - Used Power...
Need pin outs for eagle cuda 168
Coda has flat D 6 pin with center pin grd for 4 wire vs old arrow 6 pin round black one. Flat on bottom, count cw 12345 pins w pin 6 center... 2 pin minus 12 v, 4 pin +12v. For other 4 wire like speed/temp... 1 blue, 3(top) white, 5 pin bot right yellow, 6 center ground for spd/temp. White for speed wheel, rest not known. I used 2wire cable and 4wire cable with 2ft pigtails and 3amp fuse in red wire. I used old radio stereo 2 and 4 pin male female connectors at end of pigtails.
Nov 06, 2012 | Eagle Cuda 242 Fishfinder
My Maxtor 3200 has a gren light that is now blinking and the computer cannot start the drive. Code 10. What does this mean?
I had this problem. I learned that the power supply was defective. You can purchase a 12V 2amp power supply. This solved my problem. My green light was coming on but my computer didn't recognize the drive and I got the same Code 10 cannot start drive. I purchased a 12V 3amp power supply. It doesn't hurt to have more amps but you need at least 2amps.
Jan 08, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Mag lt456s power supply bad
The correct one would be 12v @ 2.5 to 3 Amp.
If the set used less current than 1 amp it would be in milliamp (500ma which is half an Amp)etc.
As long as you get one that is 12v @ 2.5 to 3 amp it will be fine.
You could buy one with a higher current rating like 4,5,6 or more Amp's as long as it's 12v DC. The set will only use the current that it needs to function so I higher current won't hurt. It's the voltage you have to make sure is correct. If you do buy one with a higher current rating it will probably last longer because it wont get so hot.
Mar 12, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Philips MMS 460 Computer subwoofer problem
Found it.....
Replaced the 1.5Amp 12v Reg with a 3Amp 12v and heatsink...also replace all the electrolitics in the same area. Reasoning being gone leaky due to hot heasink.
Remember to Silicon the heatsink down afterwards as it rattles if you dont!!!!
Oct 07, 2007 | Philips MMS 460 Computer Speakers
Televison & Video Logo
184 people viewed this question
Top Digi Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Digi Televison and Video Expert? Answer questions, earn points and help others
