Creda 79043 (no heat)
Creda Storage Heater (79043), stopped working. Replaced elements with 2 spare ones, still not heat? Todger13 rogertodger13@hotmail.com
3 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Storage Heater
You will need a volt/ohm meter. remove the element or at least the wires on each end. set the meter to ohms, touch each lead from the meter to the opposing ends of the element. The meter should have some type of resistance. If it shows open or the needle doesn't move (on the older non digital type) then the element is bad.
Posted on Jan 05, 2008
SOURCE: operating instructions for creda storage heaters
Suspect a fuse blown. These are normally easily accessible at the top of the heater, once you have ISOLATED the supply and removed the cover, very carefully. (MAY be asbestos inside, if they are old heaters...)
Posted on Aug 18, 2008
Need 4 Creda stove top range burners that are 7.25 inches round with 2 sides being square on each burner.
Creda Cooktop Product Support ' ManualsOnline.com
kitchen.manualsonline.com/support/creda/cooktop/
my gas cooktop was continually clicking and smoke ... i am looking for the manual fora creda colonial t ... Creda glass cooktop GH100, need a burner ignition.
Creda Spares, Parts & Accessories
www.4creda.co.uk/
We have parts for the full range of Creda models, so we're sure to have the part you ... Get the best performance from your Creda cooker hood with our range of ... fan oven elements, replacement control knobs, door gaskets and oven hinges.
CREDA GAS Cook Top Cooktop 4 Burner White 30" x 20 ...
bellingham.craigslist.org/app/5414687535.html Craigslist Inc.2 days ago - CREDA GAS Cook Top Cooktop 4 Burner White 30" x 20" HIGH ... make / manufacturer: CREDA ... The grates have some cosmetic chipping.
Jan 25, 2016 | Creda Kitchen Ranges
Creda topline duble oven. The single element of the upper oven is broken and its support from the roof is corroded. Can this be repaired?
The upper heating element can be replaced -- easy enough -- element costs $30 - $70.
Sheet metal can be installed over hole(s) in top and re-drilled for the element supports.
Typically, however, an oven which has holes in the liner is very old and will have other pending problems and should probably be replaced.
Charlie
Jan 05, 2011 | Creda Microwave Ovens
Not heating up
The heating element may have failed.
Feb 26, 2018 | Kitchen Appliances - Others
Creda Reversair Sensa Dry Tumble Dryer produces no heat.
There is only 1 heater element, and normally one thermostat.
they are located at the rear of the m/c, behind a removable panel.
If you are not sure whether it is the element or stat, join the two
wires togeher that go to the stat, if the heater then works, replace stat. if no heat, replace heater.
plz leave feed back for this solution.
Thanks.
Dec 17, 2008 | Dryers
Not heating up
If fan is working o/k , then you need to replace the heater element.
This is located behind a removable panel at the rear of the oven compartment,
Undo screws and remove element .disconnect leads, be careful not to lose them inside, fit new element, fit cover back.
Plz rate this solution.
Tthanks, and merry exmas.
Nov 16, 2008 | Creda C362E Electric Kitchen Range
Storage Heater
Jan 04, 2008 | Heating & Cooling
Operating instructions for creda storage heaters
how do you regulate the heat from creda storage heaters model No 79163 /79151 /79141 they have 2 dials on each heater,I was told the dial on the right turn up to 6 its highest point & the left dial to its lowest number 1 .But i got up this morning & its like a sauna
Jan 03, 2008 | Heating & Cooling
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
