Question about Uniden Cordless Phone
Line was disrupted and answering machine went down. How do I turn it back on
The unmarked bottom key on the handset needs to be turned on.
Posted on Oct 07, 2009
How to switch the answering machine from line 1 to line 2 of a two line phone
The answering machine isn't smart enough to know which line it's answering so temporarily swap lines.
Aug 07, 2017 | The Office Equipment & Supplies
Delonghi ESAM3500: - Cannot turn machine on using power button. Turning off and on at socket goes into self-diagnosis. Two whirs of the motor then it shuts down again. Is this fixable or time to throw my...
What do you see on the display when it is plugged in? Does it show the time or any other information? Does it do anything at all when you press the power button?
Aug 22, 2013 | DeLonghi ESAM3500 Espresso Machine &...
Disable answering machine
You can turn the answering machine on/off by pressing the [ANSWER ON] button as described on page 34 of this manual. This will only turn it off until it's turned back on again. To disable it permanently you'll have to epoxy the button in place or cut the wires going to the button or some other surgery.
Mar 29, 2013 | Panasonic KX-TG9344T 1.9 GHz Quad 1-Line...
I can send a fax without any problem, but am not able to receive. I have set it to send after 3 rings, but the phone rings and then my answering machine comes on. I just turned my answering machine off. ...
Set the answering machine to answer incoming calls before the printer does. For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls after five or six rings. Also, make sure the fax line is plugged into the Line port on the back of the printer and the fax settings are correct (phone number, pick-up on rings, etc).
May 12, 2011 | Lexmark X5075 InkJet Printer
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Motorola H500 bluetooth won't turn on!
Hold the phone button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
Aug 07, 2009 | Motorola Mobility H500 Wireless Headset
Took cover off my tower and blew out the dust and when I hooked it all back up my monitor said no signal and light on my mouse just flashes
Lets tackle the monitor first: A no signal message indicates one of two things;
  • The video card isn't properly seated; (if the video card is on board skip to next step) just moving the video cable on the monitor to unplug it is enough to unseat the video card. Open the tower again and make sure the card is firmly in place.
  • If the video is onboard, the plug may not be firmly in place. Check the screws that hold the plug in place and see if they are turned as far as they will go; there's a chance the plug is only partially making contact giving you the no signal message
As far as the mouse goes, the only reason the machine won't recognize the mouse would be a faulty connection in the USB port. Assuming no damage was done while blowing the dust out, double check the USB port, maybe even changing ports to see if the mouse comes back. If your machine is anything like mine, space behind the tower can get kinda cramped and just putting it back into place and reconnecting the power cord can pull just enough on the lines to pull a line just enough to disrupt your connection.
Hope this answers your questions. Best of luck.
Greg
Jun 04, 2009 | ASUS P5S800-VM Motherboard
When I boot up the screen is all colors and lines
It sounds to me like your cable is loose to the lcd or the video card is not properly 100 percent seeded into the mother board. Prolly the cable in one way or the other, perhaps bad cable.
Nov 21, 2008 | Toshiba Satellite A215-S7422 Notebook
FAX, MODEL 920 NOT RECEIVING
Try calling your fax machine from a cell phone. If the fax doesen't answer, or if the line is busy, the phone line may be bad. Also check that the phone line to the fax is plugged into the receptical marked LINE, not PHONE. The PHONE receptical is to connect a telephone to the fax machine. If it still does not answer, try going into the fax menu and go to RECEIVE settngs. Try changing each setting, then call the fax with the cell to see if it answers. Write down each setting before you change it, so you can set it back if changing it does not solve the problem.
Jul 10, 2008 | HP 920 Plain Paper Fax
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
