Question about Legacy Audio LA370 Car Audio Amplifier
Subs and amp dont work
I had a working system 2 subs and an amp. I was not sure if my friends amp was working so i disconnected my amp and connected the cables to his amp. When his amp did not function i reconnected my amp and subs but unfortunately it wont work. please help!
    Problem Solver:
  • 12 Answers
His amp probably blew your fuse. Check that you have 12V at the power connections. If you don't, then find the fuse in your positive wiring to the amp. If you do have 12V to the amp, check your remote power up also has 12V between that and the negative line when your head unit is on. If it doesn't, then it's probably an internal fuse in your remote switch on line inside your head unit caused by a fault in your friends amp. This is normally accessible at the back of the head unit.
Posted on Oct 06, 2009
Bose Acoustimass Subwoofer not working; front/center are working
Ok, have you tryed to unplug all of the wires from the sub, including the power wire from the wall. Install of the speaker wires to the sub, and plug back in the sub. Also what are the numbers on the speakers and the sub.
Jun 10, 2007 | Onkyo TX-SV525 Receiver
Installin car systems
you dont want to connect both of those amplifiers together. You could run them separately to separate subs or the jl to your sub and your alpine to your front speakers. But you dont ever want to mix and match amps to the same sub. Even if you had 2 jl500/1's you wouldnt want to just hook them up together. Because they both have to be putting out the exact same amount of power. Which no 2 amps are ever exactly the same. Some companies make bridges to properly connect 2 exact amps together. I Hooked up 2 JL 1000/1's to each voice coil on a 13.5 W7 and i smoked the sub. So i definitely dont reccommend doing it unless the amps are conneccted to separate things.
Apr 28, 2010 | Jl Audio 500/1 Car Audio Amplifier
I hooked up my two 10 inch JL Audio W3v2 2 ohms to a mono JL Audio 500.1 amp and the subs will not work. I have the subs wired in a series. I then hooked them up to my friends amp and the subs worked. Any...
try one at a time. if they work then try hooking them up differently. if none work, then check to see that your amp is not in protect mode. if amp is ok, then check to make sure you have your rcas connected to your amp. in other words, re-check all your wiring. if still nothing, try your amp on your friends car and vise versa.
Apr 01, 2010 | Jl Audio 10W3v2 Car Subwoofer
THE HA2000.2 AMP WAS WORKING FIE FOR A WEEK THEN THE PROTECT LIGHT CAME ON AND WE DONT KNOW WHAT THE POBLEM IS
Disconnect the 12v from the amp and let it sit for a minute then hook it back up. This will reset protection. It needs to be completely disconnected from the car.
Check how the subs are wired. Make sure they are not wired to 1 ohm. that amp is not stable at 1 ohm. It is at 2 and 4 ohm. make sure the subs are not wired any lower.
the ohm load is the main reason for an amp going into protection.
Dec 05, 2009 | Computers & Internet
Subwoofer buldging out problem
When speakers are wired in the wrong way the will do the "pushing out" you're describing. Basically the polarities have been reversed and if kept like this over a period of time will blow the speaker. Best thing to do is to disconnect the power by the negative on the amp and take out the fuse from the power supply. Check the wires running from the amp to the subs, negative to negative and positive to positive. I know it sounds basic but many people do mix it up! I would also check to see what channels the subs have been wired into?
Best way is to have one sub from channel 1 and the other sub from channel 2 for example. Or if its a bridged 4 channel amp, have 1 sub running from channel 1&2, and the second sub running from channel 3&4 still making sure of the polarities. Again this all depending what kind of amp and sub you have.
For example;
A 4 channel (bridged) 1000W amp. 250W max per channel or 500W per 2 channels! So if you have 2 500W subs, by connecting one to a single channel will decrease subs ability due to the lack of power supplied. However by combining 2 channels you optimize the output!
Once you know all your wiring from your amp to subs are ok/good connections/good wires etc you shouldnt have to "wiggle the wires" to get it to work as this is just a bad connection. Also ensure that no 2 wires are touching. Make sure that the master volume on the amp is turned down. You dont need this to be on loud at all, in fact far from it or you'll risk damaging both the amp and subs!
Hope this helps!
May 27, 2009 | Car Audio & Video
Amp is on but wont work...please help!!
Hello lillj2323,
OK, you say that the amp won't get your RF Punch's to pound. You do not say if you get any output at all. So let's start from the beginning.
The KAC-X542 is a multichannel amp with 2 sets of stereo outputs, 1 set of stereo outputs and 1 bridged connection for sub(s), or 2 bridged connections for sub(s).
Make sure that both 30A fuses just to the left of the power connections are good.
Check that the "ID number" is set to "0". Make sure that you have RCA inputs to both channels A and B (leftmost pairs of jacks). Your subs should be connected to the 1st (+) and 3rd (-) of each set of output terminals.
Make sure that there are no broken off plugs or pins in the jack marked "H/U Terminal" or either of the 2 jacks marked "remote".
Check that the amp is set up for 2-channel bridged. The 6 switches below the filter controls and the filter pots should initially be set:
1 - Middle position (off)
2 - Up position (on)
3 - Down position (off)
4 - Up position (mono)
5 - Down position (off)
6 - Up position (mono)
The pots should be set approximately:
LPF - minimum
HPF - maximum
Input Sensitivity - match your head unit - probably between 1 - 3
HPF - maximum
After you get the speakers working, the LPF, HPF and Input Sensitivity can be tweaked for best sound and lowest distortion.
Hope this helps.
Apr 17, 2009 | Kenwood eXcelon KAC-X542 Car Audio...
Car sound system. only sub is giving off sound. other 4 speakers dont work at all
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Dec 13, 2007 | Kicker CompVT CVT654 Car Subwoofer
Led light keeps flashing on my phoenix gold amp
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Remember to disconnect all power including ground for about to 1/2 hour to discharge capacitors. You might get lucky and get a reset. .A thumbs up would be greatly appreciated if this answer is helpful to you. led-light-keeps-flashing-phoenix-gold-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Aug 07, 2007 | Phoenix Gold Xenon-600.1 Car Audio...
Cant get the red led light green again
Disconnect all input and output cables and check. If the light stays red, it suggests an internal error. If not, proceed by first connecting the Sub wires and checking, then the input RCA's and checking. Remember to switch off the system before connecting/disconnecting, I suggest also removing fuses during this process.
Mar 11, 2007 | Pioneer GM-232 Car Audio Amplifier
Legacy Audio LA370 Car Audio Amplifier Logo
87 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
