Question about Radio Communications
Problem with the talking.
I don`t need to push in the speak button to speak, and then the other person here all of that i am saying when i don`t wont him to here it. Is that a mode? Or is it just like that it is.
  • 121 Answers
Not sure what model/make you've got but what you describe is called the VOX feature. This normally needs to be turned on or will activate automatically if a headset/mic is plugged in. How it works is that the mic will pick up initial noise of you speaking and make the connection. Normally it can be set to turn off after a period of silence.. But as I said, without knowing the make or model I don't know if your radio has this feature or if it's a fault.
Posted on Oct 07, 2009
I NEED TO SPEAK TO A PERSON HOW DO I DO THAT?
Pick up phone, press button for calls, put in number, press green button, wait for call to answer and speak.
Speak to somebody ABOUT your phone? Phone you phone carrier or the place that you bought it. They have websites with Support or Contact.
Nov 14, 2015 | Cell Phones
How to use the motorola talkabout 101
The Talkabout 101 is a very basic walkietalkie radio. With good batteries installed in the battery compartment, you should be able to turn the radio on, and simply press the front-center push-to-talk (PTT) button and speak. Release the button after speaking so the other person can do the same to talk back to you.
If you are having trouble opening the battery compartment, pull down on the black u-shaped sides and the back portion of the radio will slide down with the u-shaped sides to reveal the compartment. (This would be one of the most common questions asked on this style radio.)
Best regards.
Aug 30, 2014 | Motorola Pair Talkabout 101 2 Way Frs...
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
ser Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
HOW CAN I DEVELOP MY COMMUNICATION SKILLS?
With the lack of information i can only assume that you are referring to your written communication skills. Really its just practice, and treating people politely.
People dont usually like it when you type with all caps, so make sure that caps lock button is off :)
Other then that, just talk to people with respect, try to be a nice person, use punctuation.
May 26, 2011 | YouTube Videos
Is it possible to do 3 way calling with the Panasonic KX TG6071B
Not unless the phone as 2 lines but u have to call the both people or the person you called can but it go's both ways you just have to press the talk button then call someone then press talk again then call that person then press talk again and you all three should be on the same line
Nov 18, 2009 | Audio Players & Recorders
Hang up
Button on side is not for answering calls.
PTT or Push To Talk allows you to use your mobile like a walkie talkie. It is dependant on your network operator running the service.
Quote from Pocket lint:
To use the function you must first create a group or individual in your phone menu and send an SMS invitation to those you wish to join. Once your contacts are set up, your phone shows which members have their handsets switched on with push-to-talk enabled, in the same way that instant messaging works online. By pushing a single button on the handset, you are connected with one person or with your group. There is no need to dial numbers, nor do the recipients need to answer calls. You simply push a button and talk. As with a walkie-talkie, anyone in the group hears you almost instantaneously. The talking is one way with only one person able to speak at a time. Unlike walkie-talkies, which are infuriatingly dependent on distance, push-to-talk has no such limitations.
You should be able to disable PTT in the Nokia menu, which is best if your network doesn't support it. Plus you won't keep cutting off calls.
Apr 23, 2009 | Cell Phones
Simple HOW-TO
If your radios are set identical to one another, you simple need to press the push-to-talk button (PTT) and hold it in while talking. Let go when you are not talking, in order for the other person to be able to press their PTT and talk back to you. The monitor button is only for checking to see if other users are talking on your same frequency, and if so, you are to be polite and not talk over the top of them. (So the rules say.)
Oct 09, 2008 | Audiovox Radio Communications
Conference call
While speaking to one person, press the "conf" button... Wait for a beep beep, hit 9 then dial the other number... talk to the new person... press "conf" again... talk to everyone
Nov 08, 2007 | Panasonic KX-T7633 Corded Phone
Sound settings
When you are talking to the other person the volume keys are the keys on the left of the phone push the up button. but it could be the speaker because the v400 was known for the speaker becomeing faulty i fixed mine from these instructions. http://www.howardforums.com/showthread.php?t=633428
Jan 03, 2007 | Motorola Mobility V400
Radio Communications Logo
95 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
