Question about Canon PIXMA MP210 Photo All-In-One Printer
Won't scan i have exactly the same problem, the scanner doesn't work, and tried changing the cable, but it didn't worked, and also by updating the drivers and stills the same, sooo the only problem that i notice is that the toner is over and that displays an error over the printer, i don't know if that affects in some way the scanner
    Problem Solver:
  • 5 Answers
You need to download the "scanning program" from canon along with the driver for it to work. The scanning program is called MP Navigator EX.
Posted on Oct 18, 2010
    President:
  • 2,306 Answers
Yes it does affect the scanner, the canon machine won't scan or fax when any inks are empty.
Posted on Oct 06, 2009
My lexmark s605 doesn't work, but the pinter and copier are all fine
Plug in usb cable from printer directly to computer then print something. If you're successful, try to print something. If you're on wireless connection, disconnect the usb cord and try to scan.
Aug 27, 2012 | Lexmark "interact s605 wireless all-in-one...
Won't scan, light doesn't come on
Make sure the printer can copy (without computer). If you can make copies, the problem may be the computer or the USB cable. If the printer does not copy also. The problem is in the scanner or in the flat cable.
Apr 10, 2012 | Canon Office Equipment & Supplies
Canon mp 980 won't even copy or scan if any ink runs out. Is there any way to change that?
Sorry, but no. As far as I know that's how all of these all-in-ones work. If the printer doesn't work because the cartridges run dry, nothing else works either. They don't allow you to use the scanner as a standalone piece.
Jul 06, 2011 | Canon PIXMA MP980 All-In-One InkJet...
My Phillips GoGear Vibe won't go to the main menu. It freezes up on the ViBE sequence. I tried soft resetting and turning it back on but it didn't work!
Reset the player using the pinhole. If it freezes again then please update the firmware on the player to resolve the issue
To update the firmware perform the below task:
  • Download the newest version of the Philips Device Manager:
  • www.usasupport.philips.com - change your country/language as needed
  • Enter in your exact model #
  • Click on the link for your exact model #
  • Click on the Software & Drivers section
  • Click on "Firmware Upgrade Software"
  • Install the new Device Manager
  • Open and run the "Update" tab
If you need any further help, please email us back so that we can continue to work on a solution.
May 14, 2011 | Philips GOGEAR SA6045 MP3 Player
I have this problem on my Canon MP210 Scanner that doesn't work! I even re-installed the driver, but nothing worked but the copier works. That mean that the hardware works correctly.
First try a different data cable and a different port. If you use a USB hub or print server, try a direct connection. Check that a known working device can connect to the computer. Check the device manager and power saving settings. What message do you see in the Devices and Printers window (Printers and Faxes for Win XP) for the MP210? What error messages do you for printing and scanning?
For Windows 7, Start > Control Panel > Hardware and Sound > Device Manager. Look for a triangle with a yellow exclamation point or a red x at the bottom of the list at Universal Serial Bus Controllers. You can try updating the drivers for the USB controller or uninstalling them and then rebooting the machine. (The computer should find and install new drivers automatically. However, you should also check in Windows Update for them (check for new updates - optional and important).) With some computers this could be the result of static at the USB ports. Disconnect all of the external devices and the power cord (computer and the outlet). For a laptop, also remove the battery. Then press and hold the power button for 30 seconds. Then put the battery back in (if applicable) and reconnect all of your cables.
For the power savings settings, again for Windows 7, right click on the desktop (anywhere there are no icons or running programs). Select Personalize. Then click on Screen Saver then choose Change Plan Settings. Next click on Change Plan Settings (for the active plan). Then click on Advanced Plan Settings. Scroll down to USB selective suspend.
Did you install the Canon driver, full software or the OS driver? Can you print any documents? (Sometimes the scanner will not respond but the printer still works.) If you have documents in the print spooler, you may need to stop and restart the spooler. (One way to do this is to launch the Command Prompt window (run as administrator for Vista or Windows 7). Start > All Programs > Accessories > right click on Command Prompt and choose Run As Administrator. Type "net stop spooler" without the quotes followed by enter. On the next line, type "net start spooler" again without the quotes and press enter. Now restart the computer.
If the printer works, but the scan buttons do not. If you connected the USB cable before installing the Canon driver, you have a generic driver that may not run the scanner. Uninstall the driver, unplug the data cable and then reboot the computer. Then install the full featured software (if available) from Canon http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210?selectedName=Specifications#DriversAndSoftware . Next try to scan from the computer. You need to set up the full software with destinations for the scanner buttons and the monitoring program must be running. (If you use the basic driver, the scan buttons will not work. In Windows XP, Vista or 7, you can acquire scans with Paint. File > Import from Camera or Scanner > New Scan. Vista comes with Photo Gallery that can also do this (it can be downloaded for XP and Win7). Vista and Windows 7 also include Windows Fax and Scan to acquire scans.
If the unit still fails to work at the current computer, try connecting it to another (with known working USB ports). If it still fails, then the USB port has failed in the all-in-one. This could be another static issue. With the printer on, unplug the cables (data and power from the printer, outlet and the computer). Press and hold the power button for 30 seconds to a minute. If this doesn't help, if the printer is under warranty ask Canon to repair it.
I hope this helps.
Cindy Wellls
Apr 24, 2011 | Computers & Internet
HP F2280 won?t scan multiple pages into a PDF file
I fixed this by Installing the full suite of programmes on the installation CD, specifically Installing the "OCR Isis" programme (or Iris, not sure).
I had the scan-to-pdf option, but then when I reinstalled my system it was no longer available. I tried updating Adobe Acrobat reader to v9.0 and I don't think this fixed it. But at the same time I installed the "extra" programmes of the HP Installation CD, and then the scan-to-PDF feature was back.
So basically, install the COMPLETE set of programmes on the HP installation CD seemed to fix this.
I have a HP Deskjet F2180 printer, but I suspect that the HP software is generic across alot of its product range.
Cheers! - Hope this helps someone.
Darkeman
Oct 19, 2009 | HP Office Equipment & Supplies
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Scangear - scanning problems with mp600
windows XP instructions.can be easily applied to other operating systems
-turn printer/scanner on
-go to control panel
-click on system
-click on hardware
-click on device manager
-click on imaging devices
-right click on canon mp600 and choose updat driver option and then after that is done.click on scan for hardware changes
(below images provided)
this should make sure scanner work.. but if it still doesnt work then go back to the device manager and check if there are any hradwares with a yellow question mark beside them.if there is then right click on them and click update driver.
if that does not solve the problem try reinstalling the CD or go to the canon MP00 web page (google it) to dowmload the printer/scanner drivers. and repeat everything until it works or until you give up =). hope it all works out bye!
Apr 02, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp830 will not scan
I am experiencing the same problem, from the equipment id does not scan
Oct 31, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Download drivers from the web site do not work
Dade, You didn?t mention exactly what you installed but here is the link to the 18 MB driver and software download from Mustek for your scanner: http://www.mustek.com/supportdrivers.aspx?model=1248%20UB&category=Scanner&series=USB%20Port Make sure you follow the instructions listed on the page; pay particular attention to the part about unplugging the scanner from the computer before installing the software. If you have any other questions let us know and don?t forget to rate the posting.
Jan 27, 2007 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Canon PIXMA MP210 Photo All-In-One Printer Logo
207 people viewed this question
old marine
old marine
