Question about GE J Series 18.2 cu. ft. Top Freezer No-Frost Refrigerator TBX18AABWW
Refrigerator works fine except water draining into refrigerator from freezer in the back and the freezer has water collecting and freezing in the bottom of the freezer. There is no cube maker attached, model # GTS22JBP
  • GE Master
  • 1,606 Answers
You will need to remove the small cover on the top of the large piece mounted to the top of the freezer . There , you will see 2 screws which need to be removed . This will allow you to remove the large piece . The piece on the rear wall can now be slid up and removed . Remove the screws holding the rear panel and remove the panel . If you have an ice maker installed , it will need to be removed . Using a hair dryer , start defrosting about in the center , just below the coils , until you see the drain hole . Use hot water to help thaw the hole . Once water runs down the hole , use a small hose inserted into the drain , and blow out any unseen or built up debris in the drain line . Reassemble in reverse order .
Posted on Oct 14, 2009
Samsung RS2630sh. Drain line Freezes shut. Water drains to bottom of freezer and freezes there. Cooling coils are not collecting ice. Drain line has been cleaned. Why does it keep freezing shut?
If water still collecting and freezing at freezer bottom then drain line is not cleared and still obstructing the normal flow of water downward.
Aug 22, 2017 | Samsung Refrigerators
I have a hotpoint refrigerator freezer that works fine except i am having issues with the ice maker. The tube carrying the water to the ice maker goes through a support cup. Water has started freezing in...
Make sure tube is pushed all the way into back wall tight.Then make sure tube angles downward so water completely drains. This is a goofy GE problem.
Aug 16, 2011 | GE Refrigerators
Condensate line is plugged,water collects inside
your drain is plugged. water should drain out of freeze into ref. then collect in pan . u just need to find the drain in the freeze. need more help let me know.. ok
Feb 11, 2011 | Kenmore 64802 Top Freezer Refrigerator
Ice collects at base of freezer section
if drain hole is blocked ice will build up at back of unit. instead of moisture draining out it will freeze.manually defrost unit(no hot water) clean out drain hole with fine wire on small cloth dipped in clorine bleach.this will kill any nasties and inhibit regrowth.
Feb 09, 2010 | KitchenAid KSRK25FVMK Stainless Steel Side...
Water is leaking under the refrigerator. This is
If everything else on the refrigerator seems fine (freezing and refrigerating are fine), then you probably have a problem with the drain hose under the evaporator coil. On frost free freezers, there is a heater that comes on periodically to melt off all the frost on the evaporator coil, and that defrosted frost (water) goes out a drain hose and collects in a pan at the back of the unit where it can evaporate.
Either the drain is clogged with ice inside the freezer, (in which case you might notice ice building up on the bottom of the freezer, or perhaps water collecting on the bottom of the refrigerator if your freezer is on top) OR there is something wrong with the pan at the back of the refrigerator, like a crack, or it somehow got tilted so that the water pours out. It is located behind the panel on the back.
Or perhaps, and this would really ****, the water line that supplies your ice maker is leaking, if you have one. If you do have one, I would recommend turning the water line to the fridge off before pulling the fridge out.
Sep 14, 2009 | Kenmore Refrigerators
Water pooling underneath bottom drawers
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
May 28, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
GE TFX20JR side by side/water leaks out freezer during defrost
Yes, you are correct, that is a drain. Use a turkey baster with hot (not boiling) water to flush out the drain tube until water will flow out into the drain pan under the refrig. (where the air blown over it will cause it to evaporate)
Jan 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water collects on shelves in refrig.
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Water collecting in Refrigerator freezer section
the drain hole could have ben clogged with dirt and now with ice as the water did not drain as it went back to freezing mode. un plug the unit, let the ice thaw for a day, open the rear cover of the freezer and clean the bottom part of the evaporator. you can find the hole at the bottom part of the drain pan. i hope i was able to help.
Jul 05, 2008 | Kenmore Refrigerators
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Refrigerators Logo
152 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
