Question about Zenith ZDA311 DVD Player
Does the phillips flat screen tv have to be on a particular channel to operate the dvd player
  • 325 Answers
Yes it has to be on the right av/ext
If you have connect the DVD player via a Scart lead all you have to do when your TV is on is then turn the DVD player power on and this should auto change your channel for you..... The scart lead send a voltage upto the tv so this changes the channel for you.
If this for any reason does not work. Then you will have to use your remote for the TV to flick through the AV/source button until you get to the DVD
Hope this helps you out.
Cheers Little Dish Fitter
Posted on Oct 06, 2009
Why will sound work on dvd player but wont work when just tv on
Your dvd operating system matches that of your screen but you need to no the system of your country air tv & change it to auto or the particular r country code either pal ,secam,ntsc
Apr 11, 2015 | Emerson Televison & Video
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
How do I find out how to put the tv on the right input on an older model phillips tv
Look on the back of the tv, the sockets that various leads are plugged into will have names next to them e.g. SCART-1 or AV - IN or RF IN. Make a note of which socket is used by your DVD player, VHS etc. with the TV on, switch on the device you want to use, let's say you want to watch a DVD. Some DVD players send a signal to the TV and the TV will automatically switch to the correct channel. If not you will have to select the channel manually. On the remote for the TV, look for a button marked "AV", "AV IN", "INPUT" or "SOURCE" press this button and you will either see a list of possible inputs, in which case, choose the correct one for your DVD player - e.g. SCART-1. If you don't see a list, the screen should flicker, go black, blue or straight to the DVD player. Keep pressing the button until you get to the desired input channel. To go back to normal tv, press TV on the remote or you may need to press the input button a few more times - depending on your tv.
Apr 05, 2011 | Televison & Video
Digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Apr 01, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
Connect TV to dvd player
hdmi, S-video or jack are the most common cables delivered with the dvd, you can plug an amplifier between tv and dvd for a dolby system.
Turn on the DVD player, the TV and Set your TV on "AUX" or "Ext" with the remote.
Dec 23, 2008 | Philips TV Tuner Video Capture PCI Card -...
Can't find dvd channel on my tv...
hi does your dvd player have scart lead connection if yes select av1 or ext1 thanks
shaun
Mar 06, 2017 | Zenith SY2569X TV
Problems playing my Phillips DVD/ VHS with my new WESTENHOUSE HDTV
I notice this was made in 2008 and I hope you have found the answer. But if you or others have not here is my answer. Are using the RCA cable from the output on the DVD Player and you have plugged it into the RCA in ports then you need to use the remote to move through the on screen menu. My INSIGNIA has a Source List menu on the remote that shows on screen. I can scope through the MENU for TV, Composite Side, S-Video Rear, S-Video Side, Composite 1, Composite 2, VCR, HDMI 1, HDMI 2, HDMI 3. That is found using either the INPUT button on the upper left on the remote or the buttons; VIDEO, COMP, HDMI, AND TV across the top of the remote. Hope this helps.
Apr 13, 2008 | Philips Televison & Video
Magnavox hd2504
try turning the dvd player on,and
inserting a dvd,and then switching
to video the tv has to have a silgnal
when you switch to video the dvd
players splash screen should come
up,and then it will load the dvd
Nov 21, 2007 | Sanyo DS25390 TV
Samsung Remote Issues
if the tv is a new tv along with remote take it back to the supplier it should still be on warrant.good luck
Apr 18, 2007 | Samsung (BN5900218A) Remote Control
Zenith ZDA311 DVD Player Logo
51 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
