Question about Denon DN-HS5500 Turntable
Denon DN-HS5500 Cue Slip
These players suffer from 'cue slip' which prevents you using the platter correctly, see Denon DJ forums about this fault, Denon keep promising a fix which never appears, anyone found any solutions
Try changing the platter speed from 33rpm to 45 rpm The menu for this should be in the preset section on the player.... Good Luck
Posted on Dec 10, 2009
No enciende mi denon 1200
HOLA TENGO UN DENON 1200 LO ACTUALICE Y NO PRENDE NI HACE NADA XFA QUIEN PEDE AYUDARME
Nov 07, 2012 | Denon DN-S1200
SYSTEM ERROR EN LA PANTALLA
hola tengo un denon dns 1200 y sale en la pantalla systen error
Apr 19, 2012 | Denon DN-S1200
I installed a cd rom and it keep saying device disconnected the rom is good cause i try it on a next player need help regards knox
My suggestion is to go to the website, and look for the support forums. Have a great support community.
May 09, 2011 | Denon DN-HS5500 Turntable
Headphone cue buttons on dnx 1500 not working and fx button they work but stick on or are hard to turn off
pulled the cover plate off cleaned switches with freeon put back 2getha all sweet but 4 how long i don't know thanks any way DAN
Dec 29, 2009 | Denon Dn-X1500 Professional DJ Mixer...
Need help with setting up my denon 5500
does denon cames with its internal hard drive..or i have to buy one
Jun 13, 2009 | Denon DN-HS5500 Turntable
The 5500 doesn't recognize the files on my ipod, which are mainly cd's impoted to itunes, so i converted all the files to MP3 but it still isn't recognizing the files. what do i do?
Actually there are 2 possible solutions to your problem. When you plug in your Ipod or USB drive into the Denon HS5500 the machine will put a file on the drive called "Denon_DJ". This file needs to be deleted each time you add new mp3's to your ipod or usb device or your new files wont be shown.
The second has to do with what type of mp3 you are using and what sample rate it was created with.
For instance I record music with my computer and keyboards. I like to record in 96KHZ because it sounds so much nicer than 44.1k. Well the Denon wont read anything created with a sample rate higher than 44.1K . I downloaded a song from a DJ friend that was recorded in 48KHZ and made into a 196k MP3 file. The Denon wouldn't play it because it is not 44.1. Check your manual or check online.. the Denon reads 44.1k 320kbs and lower files only.. (Bad Denon)
You may also want to avoid what are called Variable Bit Rate files. Most files you download online are ripped at a variable bit rate. The Denon will play variable bit rate Mp3's .. But you will not be able to save cue points or save memos to the system. I found this out the hard way. So. I took all the files I had created that were VBR and put them into Audacity with the Lame MP3 plugin and set the bitrate to 320kbs and now I can save memos.. But everytime I put the USB flash drive into my pc and put new songs on I have to delete the Denon_DJ folder.. Its sad too because thats where the HS5500 stores it's playlist files... :( Bad Denon. They should have asked me to write the software.. xD
I hope that helped you..
Apr 12, 2009 | Denon DN-HS5500 Turntable
Denon DN-S3500
Sounds like it may need a motor calibration. You would have to seek out an authorized service center to this adjustment done. It's a quick and easy fix though.
Jan 17, 2009 | Denon DN-S3500
New DJM 600 User
Get yourself a manual. It will help you. You can DOWNLOAD A FREE COPY of the PIONEER DJM600 INSTRUCTION MANUAL from HERE.
Now, you have to use the CUE button function on each channel to select what you want to hear when you cue things in the headphones. Last, you control the volume of the master cue in the headphones using the CUE volume of the headphone CUE section.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
Denon DN-951FA
Push your "track selector knob" IN towards the unit and hold it in while pressing and releasing your STDBY/CUE button. This resets the microprocessor (kinda like rebooting) the unit. If you want to speak to me further about your 951fa, email me at chris at cueblip dot com Thanks!
May 04, 2007 | Denon DN-951FA CD Player
Denon DN-HS5500 Turntable Logo
443 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
