I am winterizing my Laars Lite2 pool heater and have what may seem to be easy questions but... What Do I grease the drain plugs with before I put them back after draining heater?. Should it be Silicone based? Also where do I blow the compressed air to dry out heat exchanger?.. Thru the drain plug holes? Thanks
have a problem with a laars boiler Mini-Therm II, the pilot keeps going out. the unit is about 5...
(More)
have a problem with a laars boiler Mini-Therm II, the pilot keeps going out. the unit is about 5 years old and is used for radiant floor heat.
have a problem with a laars boiler the pilot keeps going out. the thermostats only work on max as...
(More)
have a problem with a laars boiler the pilot keeps going out. the thermostats only work on max as well. have serviced the boiler and replaced the thermal coupler. the unit is about 10 years old and is used for radiant floor heat
laars lite 2 pool heater heats and then stops I checked the temp sensor and it is fine. Is this the...
(More)
laars lite 2 pool heater heats and then stops I checked the temp sensor and it is fine. Is this the temp controller?
