Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
How do you change the belt on a f7441-980 hoover carpet cleaner
  • rkintz May 11, 2010
    There are no belts on the SteamVac series. What is the issue you are experiencing?
    Scholar:
  • 190 Answers
There are no belts on the SteamVac series. If you have a brush rotation problem, please check this:
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4)Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen
Posted on Oct 07, 2009
2 Suggested Answers
  • 57 Answers
SOURCE: I have a Hoover carpet cleaner - Model #
There is a plastic piece on the back of the block brush (spin scrubbers) these wear out or break. You may need to replace the block brush. You can find the parts and a schematic below follow the link. Please don't forget to give positive feedback.
F7441 Link
http://www.usavacuum.com/Hoover-Steamvac-s/109.htm
Posted on Feb 26, 2010
Hoover cyclean brush stopped revolving
The belt may be broken or worn If your cleaner is not picking up fluff and hair from the carpet or has become heavy to push it is possible that the belt has snapped. This belt makes the sweeping brushes spin round underneath the cleaner and brush dirt into the path of the air suction. The brushes also give that 'groomed' look to your carpet by gently brushing the carpet fibre. If you pick up something sharp or debris gets jammed in the brushes then the belt may snap. Also over time your belt will stretch, so it's a good idea to change your belt once per year to ensure the cleaner picks up dirt effectively.
Dec 14, 2016 | Hoover Vacuums
Hoover advance path steamer practically new started smelling like burning now won't turn on
Service Center Locator - Hoover
hoover.com/locator/
The Hoover CompanyFloormate Scrub Cleaners · Steam Cleaners · Stick Vacuums · Carpet Cleaners · Parts & Solutions · Search Parts · Bags · Belts · Filters · Cleaning Solutions.Missing: advancepath
Hoover steamvac repair - YouTube
? 6:16
https://www.youtube.com/watch?v=cyenpuw2XyM
Apr 23, 2014 - Uploaded by BCtruck, rebuild, repair,repurpose
Its ben two years since we had the carpet in the sunroom steamcleaned. It pains me to pay someone else to ...
Nov 07, 2015 | Hoover Vacuums
Where is the belt located on my hoover steam shampoer
There is probably not a belt. The brushes on the carpet cleaner head and attachments work from air and there is a roller bearing deep inside that will wear out and the brushes won't turn. I've found no way to fix this. I consider it a design defect.
Apr 20, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover deep cleaner brush won't work
If the vacuum cleaner comes on but the brush will not spin, try replacing the belt and clean each end of the brush from lint , string, carpet materials.
Oct 06, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Hoover carpet cleaner brushes do not move
did you check to see if the belt came off or its stretched?
Jan 24, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover vacuum carpet cleaner will not sucktion (sic)
No, this cleaner uses no belts.
If you are having a suction problem, first check that the lid on the recovery tank is lined up to the tank when installed to get a good seal.
Second, remove the tank and make sure the round black rubber seal is present on the pipe from the base that aligns with the bottom of the recovery tank. That seal connects the vacuum from the motor to the recovery tank.
Oct 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
212 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
