Question about Dell XPS M1210 Notebook
The computer wont boot up. and the screen wont display anything!
The computer wont boot up. and the screen wont display anything.whats wrong?
  • femustang May 11, 2010
    first off I am assuming that is has been in use for a while then quit. what lights do you have at the front of the pc are you indicating a charge with it pluged in? are there any red lights coming on? if its over a year old your battery may be dead or faulty if its newer. pull the battery and see if it will boot on just power supply.
  • David Rooker
    David Rooker May 11, 2010
    What operating system are you using? And did you drop it or add any new software before this started happening?
    Scholar:
  • 67 Answers
Take a multimeter and verify the AC adapter. If it is ok, remove the battery. When you push the power on button do you have any activity ? If there is no activity the motherboard is defective. If you have some activity (leds on, fan activity etc.) :
1. check the memory :
- if you have 2 memory modules use only one at a time, the other one could be defective or
- check your memory with another laptop or
- use some known good memory etc.
If the memory is ok then :
2. Connect an external monitor to your laptop. Turn the laptop on and see if you get any video signal on the external monitor (you have to use the right button combination e.g. Fn + one of the Function keys). If you get a signal then the problem comes from the screen/backlight/inverter/cable. If there is no video signal on the external monitor then most probably the motherboard is defective (at least the integrated video card). Expensive to fix or to replace it. Have it checked by a professional.
Do you have any warranty on your laptop? See your dealer or HP representative first.
Posted on Oct 06, 2009
    President:
  • 2,600 Answers
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Screen won't come on my asus laptop.
Laptop screen won't turn on, but works with external monitor ...
www.tomsguide.com/.../laptop-screen-turn-works-external-monitor.html
Oct 16, 2015 - Hello, my laptop screen won't display anything. It boots up and ... External Monitor; Function Keys; Laptop Screen; Windows 8; Asus. Display.
ASUS laptop screen won't display anything - Tom's Guide
www.tomsguide.com/answers/id.../asus-laptop-screen-display.html
Aug 28, 2013 - My laptop screen won't display anything Forum; Asus n56vz laptopwont ... i cant remove the asus battery to my laptop and the screen wont turn ...
Asus laptop black screen problem - YouTube
? 7:52
https://www.youtube.com/watch?v=gRQgN5AT3a0
Aug 2, 2011 - Uploaded by mrwangyanfei
Black screen when switch on Asus laptop (N61J) ... I turn on mypc and the screen stays black. I tried ...
Dec 13, 2015 | ASUS Computers & Internet
My cpu overheated and now my video,keyboard,mouse,and usbs wont work! Whats wrong with it. Do i need a new fan?
Why did it overheat? In cases where a CPU has overheated, it more likely you will need a new CPU. If you can get one. Does the fan run? Is there dust in or around the heatsink? Have you booted the PC? If so, does it start to boot? Does the operating system load up? Anything displayed on the screen? Any errors on bootup? Rgds, Dave.
Mar 04, 2014 | Intel DQ965GF Motherboard
Pls guys i need your help my zinox laptop would on but wont display anything ,initially i taught i was the screen but one day i on it down for some mins and it display and wen d battery went down i charge...
Computer does not boot up
The problem maybe the RAM, it could be faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
May 12, 2013 | Computers & Internet
I have an HP Mini 110-3135DX. When I turn on the power all that is displayed is a blue screen and it wont boot. How do i fix it?
check you bios pages are correctly configured,,goto bios navigate with "tab" and arrow keys,,play around untill you know these pages dont change anything untill you are sure you know what you are doing..Exit and save pay attention to boot sequence if this is set up wrong it might cause failure in the way you describe,the instructions on the right hand side of the bios pages should help you---good luck --Davey
Jun 20, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
Laptop powers on fine , I can go into and change BIOS settings and everything is fine.. After the COMPAQ post screen the laptop wont boot from any media what so ever. It just displays a blank black...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 13, 2011 | Computers & Internet
Replaced lcd display for dell 1525. need help!
Try re-connecting/re-seating the video cable/connector again.
Feb 13, 2010 | Dell Inspiron 1525 Notebook
Computer won't load past Boot and now doesn't display anything!
the memory stick going in one way into the module. If you can't close the clips try to rotate it 180 degrees.
when windows starts hit F8 key and select disable automatic start on system failure.
This will bring you a blue screen with the specified error
also you can boot from windows xp cd and at first screen select repair, this will put you in recovery console
in recovery console you can scan your hardrive for errors like this:
chkdsk c: /p /r
Jul 17, 2009 | Computers & Internet
Screen wont light up, cannot see the screen.
press f8 after boot up ,then select option enable vga,then when it start go to control panel,
un-install the display drivers,restart and reinstall them.
Feb 06, 2009 | HP Pavilion dv7-1130us laptop
Acer one, set bios to boot from usb. but wont boot display can you help?
Hi there jack......set computer bios to boot from cdrom then harddisc.....this will allow your computer to boot actual data then display on screen...take caution when changing bios settings
Sep 09, 2008 | Computers & Internet
Dell XPS M1210 Notebook Logo
267 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
