Question about Brother MFC-7440N Laser Printer
Brother mfc 7440n printer/fax running very slow
WE have a brother mfc7440n for the business that is about yr.old and has been running very very slow when making copies. What could the problem be? Also has been going through alot of toner..
    Problem Solver:
  • 12 Answers
Depending on how many copies you have it might be time for a new drum unit. Also, you can change the settings for the resolution for copies in the main menu. Check Menu--Copy--Quality and make sure it is not set on Photo. This would definitely **** up toner as it would print at the highest resolution rather than the default resolution.
Posted on Aug 26, 2010
Does a Brother MFC-7440N printer use an ac adapter?
No., Its need a power cord. It has built in SMPS adapter.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 06, 2016 | Brother MFC-7440N Multifunction Laser...
Printer has light grey background after printing
Hi Mel:
Just a thought, is there a "greyscale" setting?
When I try to print I have the choice of Black & White, colour, and greyscale.
Hope this helps.
Cheers.
Jan 26, 2016 | Brother MFC-7440N Multifunction Laser...
I want to add orconect a MFC-7440N Brother Laser Copier ,fax, scanner to my Dell Computer I dont have the disk to install please help me
Before you start, ensure you have a USB cable to connect the printer to the pc.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc7440n_all
Use the above link to download the necessary software drivers to run the printer, scanner and fax. Select your operating system.
May 28, 2011 | Brother MFC-7440N Laser Printer
When I scan on my Brother MFC7440N I get lines down the middle of the pages. I cleaned every inch of the scanner and that didn't help. Any suggestions?
If you scan through adf there will be a mark on the corresponding part of the small glass window at edge of machine (often caused by ink). Clean this narrow strip of glass thoroughly. Hope this helps
Nov 16, 2010 | Brother MFC-7440N Laser Printer
My mfc7440n is saying toner life end, when i have put in a new drunm and cartridge(remanufactured) please help
You have to reset the toner count...There is a key combination to reset the toner.....normally there is a reset chip on new toners.....look it up on google and you should be good. Look up resetting the toner count for your machine.
Oct 21, 2010 | Brother MFC-7440N Laser Printer
We have a MFC 7440N at work. I have Windows 7. I
did you install the full suite for your printer OR just the printer drivers?
I believe if download the full suite, uninstall the old software from control panel 's add/remove programs, then reinstall the complete software you should be up and going again.
the software download is here: http://www.brother-usa.com/downloads/default.aspx?PGID=5&R3ModelID=mfc7440n
make sure you select the correct operating system as there are both 32 and 64 bit drivers. and make sure you pick the "full driver & download package.
there is also an uninstall tool at the bottom of the page to remove any older software/drivers you may have previously installed prior to installing the new software.
Apr 02, 2010 | Brother MFC-7440N Laser Printer
Can't address envelopes using Microsoft Word 2007 & Windows 7
Excellent question. Wish I had the answer. I have the same problem with the MFC-7440N. I hook up my old HL 1240 and it prints them fine, so I now use two printers - one for envelopes and one for normal printing. I contacted Brothers and was told that it was not the printer, but the Application. If so, then why does my old Brothers printer work? They do not have the answer.
Feb 24, 2010 | Brother MFC-7440N Laser Printer
Brother MFC7440N Toner error message
It looks like the toner cartridge is not inserted correctly.
Turn of power. Remove cartridge and reinsert it in right position. Close the door correctly. Restart.
Mar 27, 2009 | Brother MFC-7440N Laser Printer
Brother MFC-7440N Laser Printer Logo
323 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
