Question about Vocopro CDG-8000 Professional Dual CD/CDG Player CD Player
Tray's sticking on vocopro 8000 pro
Both trays have power. When I turn on the player, both cdg come up to No disk. But when I try to open either side the think kind of makes the sound of getting ready to open then a little "plunk" kinda noise and in a few seconds the err comes on the display. Any ideas?
  • 1 more comment
  • Richie56 Dec 23, 2007
    I have take this unit apart. It appears to me that the magnets that slide to the center oof the disk when you insert a disk, are clamping down on the underside where the magnet is and not letting go. If I take the crossbar off either side od 1 or two, the doors opens and closes effortlessly, when I put the crossbar back into place it does not. If I put a little upward pressure on the bar as I hit the open button it will open as well. What do I need to do to stop that?
    Ok, I still have the cover off and can watch it as it works. I don't believe that the belts are slipping. Are you talking about removing the entire cd unit or just taking the tray off. Not sure... Is this something that would be better sent back or is it doable on this end? I'm not adverse to trying if you can walk me thru it.
    Hope this works....
  • 108 Answers
Possible problems :
1. Check whether the Disk to be played is struck inside
2. Check for any jammed Door shafts
3. Check for improper Lens assembly seating on the disk
4. Check Drawer/Door motor belts stripped from its Slot
5. Check whether Door open/close sensors working properly. Manually check the sensors
6.Check whether any shafts or arrangement blocking the Door moving in/out.
7. Check Door open/close key on the Cd player got struck. if then just release it
8. Bad or weak Servo motor can also cause these issues
9. Due to some unrecognised operations the system itself says as ERR error.
10. if problem stil persists contact authorised Service professional.. thank you
Posted on Dec 23, 2007
  • 1,153 Answers
Sounds like belts are slipping under tray. They can be cleaned or replaced or new ones of course.
  • 1 more comment
  • Lashawn Robinson Dec 23, 2007
    The magnet operates correctly, sounds like you have a problem with the drive mech. This is control by a drive motor which is probably belt driven. If the belt slips it has no or not enough power to pull the magnet apart. IF everything is working like Im thinking, then you need to work with the drive area. This may cause you to take tray completely out if you cant see it when the tray opens. The only thing after this is to worry if you will place the tray back in at right point. Because it needs to be timed and if you are not use to doing it can be hard.
    If you can see the belt, you will only have to remove the tray to get to the belt, also if you can grease the plastic part of underneath the tray this will alloy the tray to move easier. These are only maintenance technics. It would only help in the future. Can you take a picture of the unit with the trays in the open positions. Thanks
    Thanks for the picture, Can really see from this angle. Can you see any belts under the tray?
The disk tray on the recording side of the recorder will not open.
use a paper clip to open. first strighten out the paper clip. make sure power is off to the unit. then with the paper clip insert into hole on the player. the tray will eject out. good luck.
Oct 24, 2014 | Audio Players & Recorders
Only de right side of the cd player worrkin
because the problem is due to spark while switching cables of any kind the inside of your cd player damage and the solution is that ,take the player to any person in the market that can make it right.
Feb 06, 2011 | Vocopro CDG-8000 PRO
Left side drawer will not open
sound like the tray belt is slipping and it need to be replaced.easy fix.should cost you about 5to 15
Jan 12, 2011 | Vocopro CDG-8800PRO
Will only play certain cd's. works great with the
try clean-it with cd drive cleaner kit. available on professional audio\video stores
Feb 21, 2010 | Vocopro CDG-8800 PRO
On my Yamaha CDC-625, I can push the open/close button or the playxchange button, but the changer door will not open. It sounds like a motor is trying to open it, but nothing. Pushing the button again...
The most common problem is a slipping belt.
You have to open-up the player to check it.
If you're not familiar with it, then please don't.
It's not such a big problem, look for a local repairshop.
HNY, Gerard
Jan 01, 2010 | Vocopro CDG-8000 Professional Dual CD/CDG...
Nikon cool scan 8000 How to load 2 1/4 by 2 1/4 negs on this tray
There is a lock on the oper side. release the lock and the other side also opens like a door
Apr 01, 2009 | Nikon Super Coolscan 8000 ED Film Scanner
I need to change region code for goodmans GDVD200CDGM
Region Code Hack: GOODMANS GDVD-200-CDG:
To convert this player to Multi-Region
1. Open the disc tray.
2. Place a region 1 disc in the tray, but don't close it.
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
4. Press the play button on either your remote or the player.
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control.
3. Press the Retu To return this player to Region 2 only (alternative method) rn button on your remote control.
4. Your player should now go into Standby mode.
5. Press the Power button on your remote control.
i). Open the disc tray
ii). Place a region 2 disc in the tray, but don't close it
iii). Press the buttons Return and then Play on your remote control in order, one at a time
Aug 21, 2008 | Goodmans Televison & Video
Disk Tray
  1. Ensure the child lock feature is disabled.
  2. IMPORTANT: If necessary, consult the instruction manual for specific steps about how to disable the child lock feature.
  3. Attempt to open the disc tray.
  4. If the issue is not resolved, turn off the DVD player.
  5. Unplug the power cord from the electrical outlet for 30 seconds.
  6. Plug the power cord back into the electrical outlet.
  7. Attempt to open the disc tray.
  8. If the disc tray still does not open, simultaneously press the POWER+STOP+EJECT buttons; this will sometimes cause the disc tray to open.
If the issue is still unresolved, service may be required. The Sony® eService Web site at can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
see this
Mar 29, 2008 | Sony RDR-HX825 DVD Recorder/HDD Recorder
DVD Tray will not open
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Cd tray doors won't open
Check mechanics on CD door for dirt, or any loosen screws.
Oct 01, 2007 | Vocopro CDG-8000 Professional Dual CD/CDG...
Vocopro CDG-8000 Professional Dual CD/CDG Player CD Player Logo
317 people viewed this question
Top Vocopro Audio Players & Recorders Experts
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
