Question about Lexmark 4227 Matrix Printer
THE WORK ORDER MACHINE IS GIVING ME A CA DRIVE ERROR IT IS A LEXMARK 4227 MACHINE.
    Problem Solver:
  • 15 Answers
Error: "637 Machine Check CA Drive Error"
Tear off any paper at the top of the printer.
Press the Load/Unload key.
Turn the printer off.
Press and hold the FormFeed button and turn the printer back on as you do so. Note: Hold the FormFeed button down for a full three seconds after turning the printer on before releasing it.
Press the Micro Up or Micro Down to change the value of the position "Pos = XXX".
Press the Tear Off/Store button to save the setting.
If needed, repeat steps 1-6.
Posted on Jul 09, 2010
What is the powder charge for 357 magnum using IMR 4227
What weight is the bullet
As a 146grn starts at 14grns 4227 to 16 grns Max
So if you post the bullet you want to reload can give you a better idea
Apr 30, 2015 | Optics
I've lost the CD for my printer Lexmark forms printer 4227 plus. I need the driver for Windows 7.
The link below will take you to a webpage that may help in understanding problems with lexmark and windows. Use this only to read up, the link to lexmark drivers appears afterward.
http://driverupdate.net/articles/lexmark-drivers?aps=article_Lexmark_Drivers#download
Here is the link for lexmark drivers, enter your model info in the box:
http://support.lexmark.com/index?page=productSelection&linkSelected=node0&locale=EN&userlocale=EN_US
You may find this link helpful in determining whether your machine is W7 compliant
http://support.lexmark.com/index?page=content&id=os6&locale=EN&userlocale=EN_US
I hope this helps.
Mar 28, 2011 | Office Equipment & Supplies
Lexmark Prospect Pro 205 printhead error
Sounds like you need new printhead. Take a look on amazon for replacement, here: Genuine Lexmark 100xl 100 Print Head 14N0700 14N1339 Printhead for Lexmark.... I hope this was helpful, Cheers
Jan 07, 2011 | Lexmark Office Equipment & Supplies
Error message: HARDWARE PROBLEM ERROR CODE 0502 Only prints top part of page and then gives error code raabe@shaw.ca
Refer to this article from the Lexmark website on Error 0502 on the Lexmark X6150/X6170 Printer LCD Display. If error continues even after following the steps, contact Lexmark technical support for additional assistance. Thanks.
Jan 06, 2011 | Lexmark X6150 All-In-One InkJet Printer
How do i run a configuration page from the printer?
Dear Friend,
Read this Guide Click Here(This may take a few time According to Connection Speed)
Hope This Helped you..Thanks for Contacting FixYa
May 14, 2010 | Lexmark 4227 Matrix Printer
The check light is on very faint all the time and cannot clear paper jam message.
Please call into our technical support team its free as long as parts are ordered thru us.
Thanks,
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 02, 2009 | Lexmark 4227 Plus Matrix Printer
Error code E000732-0001
This error indicates that it cant detect the scanner unit of IRC3220
Check the cable that connect the machine and scanner unit .switch off the machine disconnect the cable and reconnect it and switch on the machine again hope this will help
Jul 01, 2009 | Canon imageRUNNER C3220 Color Copier
Lexmark 4227 Plus Matrix Printer on Vista
Operating System Printer Driver Installation Procedure
NOTE: This procedure involves driver installation and port creation using Microsoft's Standard TCP/IP printing.
Step Action Click on Image 1 Click on the Microsoft logo start button. pattlnk_3212007_1551-vistastrtsm.jpg 2 Click on Control Panel. Image 3 Click on Hardware and Sound. NOTE: Classic Mode users can double-click directly on the printer icon. Image
4 Select Add a printer.
Click for Image 5 Network installation
Select Add a network, wireless or Bluetooth printer (for direct IP printing, network print queues - \computernameprintername, etc.)
NOTE: For printers connected via LPT1 (parallel), select Add a Local printer (e.g. IEEE- 1284 compliant printer cable, etc.)
Image 6 Observe Searching for available printers...
Upon completion, select (highlight) your printer, and click Next.
Your printer's IP address will be displayed under the printer description. Use the IP address obtained under Recommended above.
Available Windows Vista Search options:
  • Stop Search - Select this if you can identify your printer prior to search completion.
  • Search Again - If your printer does not appear,determine whether the printer is on the same segment of the networkand confirm successful communication with the printer.
HINT: Windows Vistawill only search the local subnet. If you are confident that theprinter is communicating over the network, select The printer that I want is not listed and try to add the printer's IP address manually.
Image 7 Observe Detecting the TCP/IP Port...
NOTE: Windows will automatically move to the next page when the detection is finished.
Image 8 Observe Detecting the driver model...
NOTE:
Image 9 The Printer name will appear, click Next.
Optional: If youwould like a distinctive printer name and do not want this printer tobe your default (i.e. main) printer, enter a different printer name and deselect Set as the default printer. Image 10 Observe Installing printer... Image 11 Upon completion, a Windows test page will print. You can verify the printer's installation by opening the printer's window.
Feb 23, 2009 | Lexmark 4227 Matrix Printer
Problem with L100 TAPE LIBRARY
I'm having a similar issue.. anyone know how to fix these?
CH 2635
Library.c
Line 4231
Path 0000
Aug 12, 2007 | Sun StorEdge L100 Tape Drive
Lexmark 4227 Matrix Printer Logo
412 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
