Question about Bosch Dryers
I have as Bosch tumble dryer wte86308. I have
I have as Bosch tumble dryer wte86308. I have lost the user manual.
The filter light keeps flasing during a drying cycle.
Cleaning the filter, the lint tray and emptying the water container makes no difference.
Can anyone help please?
Thank you very much.
  • 213 Answers
SOURCE: Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Posted on Nov 20, 2007
SOURCE: Bosch tumble dryer
I have the same problem. Have you found a solution yet. Cheers Andrew
Posted on Jul 10, 2008
  • 82 Answers
SOURCE: lint not catching in tray and is clogging the roof vent
This is common on all dryers. Not lint screen will catch all the lint although some are better than others. If you haven't already, you will need to clean or have your home vent cleaned (with a brush that goes all the way through the vent). If vent is not cleaned the lint will back up all the way into your dryer and cause a mess. You have stated your vent goes up to your roof so you will need to clean it every 6mths to 1yr. Aside from this there is no fix that I am aware of. Please rate me after reading this.
Posted on Dec 14, 2009
apart4u
  • 213 Answers
SOURCE: Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Posted on Jan 10, 2010
  • 767 Answers
SOURCE: Maytag MCG8000AWW gas dryer no heat
The ignitor may be bad you can chek to see if there is 110volts when the dryer is allin by unplugging the wire to the ignitor and putting using a multimeter to chek for voltage at the wires. If there is power to the ignitor and the ignitor is not glowing up then the ignitor is probably bad replace the ignitor.
Posted on Jan 12, 2010
Testimonial: "Thanks so much, this information really helped us so much. This is the best site ever!"
Bosch WTE84122BY Condenser Tumble Dryer dosen't starts
Did you check the res to see if it was full? Might be clothes inside the door and it aint shut all the way? never even seen a condenser dryer.
I have the model service manual though HERE
Dec 11, 2013 | Bosch Axxis WTA4400 Dryers
I need the user manual for Bosch WTL 4613 electronic tumble drier
0027 516659 Instruction manual de,nl,fr,es,en,pt,it 7.80 USD Unfortunately my search on-line for this manual came up short. You can order one directly from bosch at their appliance website. The cost is $7.80, the part number is 516659. Weblink: eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTL4613%2f01&ESHOPTYPE=A">http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTL4613%2f01&ESHOPTYPE=A
Jan 30, 2011 | Bosch Dryers
Looking for manual for the bosch wta 2000 tumble dryer. thank you.
I've made a PDF of the Bosch WTA2000 Tumble Dryer User Manual and (hopefully) it will be available on this link in case anyone else still needs a copy, as the original request above is a bit old now.
It's a leeeettle blurry as I should have used a higher dpi when scanning the pages, but I can't be bothered doing it all again. I think it should be sufficient for purpose anyway.
https://onedrive.live.com/?cid=5D5DECF4115C2175&id=5D5DECF4115C2175!189
Nov 21, 2010 | Dryers
I have a Bosch Maxx condenser tumble dryer that wont work.
Have you taken the condenser itself out from the bottom of the machine? Remove the condenser from the bottom door and rotate the clamp tags which secure it in. Slide condenser out (aluminium mutli-finned box assembly) and carefully take it outside. Use a garden hose with lots of water pressure to spray each vent passage carefully to clear lint and dust away. Passages must be cleared in both directions, long ways and cross ways. Cross ways is the problem area and once you finish clearing the air ways you should see daylight through the condenser easily. Reassemble and always clear lint filter in the door /drum area.
Good luck.
Sam
Sep 02, 2009 | Bosch Dryers
Hi,there is no heat coming from my Bosch Tumble Dryer
USUALLY A FAULTY THERMOSTAT OR HEATER ELEMENT ASSEMBLY
Apr 09, 2009 | Bosch Dryers
I have a bosch classic xx condenser tumble dryer and it keeps stopping because the filter light is on. As soon as open the dryer and restart is works fine? Am I putting too much in?
Hi ya,
Welcome to fixya.
You have a bad filter sensor and or relay !
In a Bosch this is not a usual do it your selfer. You need a hands on experienced tech.
Please leave a solved rating before you sign off!
Huuum
Jan 23, 2009 | Dryers
Dryers Logo
65 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
