Question about ASUS KFN4-D16/1U Motherboard
ASUS KFN4-D16/SAS doesn't start
Start as i turn on the power supply, no need to use the server's power switch but unfortunately nothing happens on screen, no way to go in bios mode, the green led on the board is on and both cpu's fans are running full rpm. Very noisy but very unfunctional. The recovery bios function doesn't work. All the jumpers and wires are OK. This is the first server i worked on, maybe i have missed something. What is solution to have it run ? May you help me ? Thanks.
  • DiCompito Dec 24, 2007
    Thanks for your advise. I really appreciate how fast i got options to look over from you guys but it looks like a bad assembly in the board itself or maybe a corrupted bios or non-programmed bios and i don't have a replacement chip to follow up so i'm going to exchange it at the supplier i got it.
  • 790 Answers
Same thing had happened to me once but i just cleaned the dust on the RAM and re inserted it and it was fixed ... this is not the solution .. but just give a try ...
Have just gave an attempt ...
Posted on Dec 23, 2007
    Sniper:
  • 108 Answers
Possible problems.
1.Check your primary and secondary devices (Keyboard,Cd-Rom.Harddrive,RAM,display card) working properly or not
2. if fails then system could not able to proceed (POST)POWER ON SELF TEST
3. After POST systems boots. Using Bios utility verify Disk Drives
4. Only hard drives which produce too much Noise. Damaged hard drives might cause so Noise
5. switch off your system. Check for any cables loose connection
6. check your hard drive power cord and data cord.
7.. Due to hard drive failure system go completely blank and damaged Hard drive Booting files aslo cause
8 . Using CD-rom enable Boot and verify Hard drive working properly or not
8. if problem still persists. Contact service center.. thank you
    Master:
    Sergeant:
  • 482 Answers
Hello, I would start with the power box, check to see if you have the right one, if power box works then the only other thing is the motherboard may need to be replaced. make sure you dont have a screw shorting the motherboad out. it sounds like a short on the motherboard.
I HV PURCHASED P5BV-E/SAS EARLIER BUT TODAY I SWITCH ON THE SERVER BUT THEIR IS NO DISPLAY
Hello you can download the manual here:
http://support.asus.com/download.aspx?SLanguage=en&p=5&s=13&m=P5BV-E%2fSAS&os=23&hashedid=zuljCoD6sSH3WpYx
By selecting your windows system.
Open the manual folder and click on global for download.
You need adobe reader to read the content.
This is usually a hardware problem, Video card, power supply, memory sticks or mother
board. To nail down the problem, try the following workarrounds:
1. Does this computer work well before? If yes, what new hardware did you install recently? Remove it and try.
2. Insert one ram module, and turn on the
computer, if the computer POSTs or you hear beeps, try to add one memory
stick each time until you add all your memory sticks.
3. Clear your CMOS by removing the battery or short the jumper.
4.
Swap your hardware from the motherboard, for example, reseating your ram sticks, move video card from PCI slot 1 to PCI slot 2, etc.
5. Reseat your processor, check the CPU for damage.
6. Verify that you have all the power connectors connected properly.
7. Make sure the power supply is working, even test it on another pc.
Remember
to restart your computer after you try any of the above steps. If all
the above does not work, it is very possible that your motherboard is
bad.
Here is a fault finder guide:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Post back what is going on.
Good luck
Jan 08, 2013 | Asus P5BV-E SAS LGA775 Xeon FSB1333MHz...
Computer not powering up
bad power supply. just replace
Jun 07, 2012 | Computers & Internet
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Compaq proliant 5500 server wont power up
In my experience when a server/computer does absolutely nothing when the power button is pressed it is a dead processor. That may not be the case in your situation. It could be as simple as a defective power switch. Is the switch a soft touch or does it push in and click? Does the switch feel normal when pushed? One of the power supplies could also be bad. Do you have any good power supplies to test in the server? Were there any power outages recently that could have caused damage to the PSU? I would start with checking the switch. You could hook up a circuit tester and see if the switch completes the circuit when depressed. Also take a look inside the server and look for any loose connections on the mainboard. It is possible the wire for the power switch has come loose.
Sep 05, 2009 | Compaq ProLiant 3000/5500 Redundant...
My asus laptop cant turn on
you need to replace the Power button...
Apr 12, 2009 | ASUS AC Adapter- Universal Notebook AC...
What is the prosisor of doing one shotdown shadule of PC?
press start > click turn of my computer > click turn off ,,this will shut down ur pc
another way is click ctrl+alt+del ,,this will open the task manager ....in the upperside you can find shutdownload ,,,click that and click for turn off
Jan 14, 2009 | ASUS DSBF-DE SAS Socket LGA771 DualCore...
Open Questions:
See all ASUS KFN4-D16/1U Motherboard Questions
ASUS KFN4-D16/1U Motherboard Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
