Question about Samsung BD-UP5000 Blu-ray and HD-DVD Player
Player will not work. keep getting the disc will not work message, for all discs.
  • 6,784 Answers
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Posted on Oct 06, 2009
My Sony Blu-ray BDP-S300 will not read blu-ray disc.
You need to update your software. go to network update but you have to do it via your network it worked for me. Hope this helps
Sep 24, 2012 | Sony BDP-S300 Blu-Ray Disc Player
My device cant open the disc tray please advise me on what to do
Electronics Corporation sells inexpensive DVD players. The DVD players, however, often exhibit problems due to their manufacture and way that they work, which must be dealt with during the course of the player's life. Knowing what these problems are beforehand can aid in resolving difficulties when using the DVD player. In some cases, it can help eliminate the problem before it can become catastrophic
The disc door is not properly closed if the Disc player display shows an "Open" error message. Check that there are no gaps in the door and use the remote to open the disc door. If it will not open, unplug the Disc player and gently pull out the disc door and then push it in. Plug the Disc player back into the AC socket.
If the DVD has not been inserted properly into the disc tray, a "No Disc" error message will come up on the display. Eject the disc and lightly flick off dust using the edge of a lintless cloth. Inspect the disc for damage. Insert it carefully again into the disc tray and use the remote to close the disc door.
Because the Disk player is inexpensive, the power supply is not of the highest quality. Having a surge protector to plug into the Disc player will help to keep the power supply from being damaged over the course of its lifetime.
Have a nice day
Feb 16, 2011 | Audio Players & Recorders
Solution for "My sony sb 301 blu ray disk will not load It keeps
check with different Blu-ray discs and DVD discs. If the issue occurs only with some discs, then try updating the Firmware for the Blu-ray Player which should resolve the issue. Contact the Sony support team to get more information about the Firmware update for the Player.
May 09, 2009 | Sony BDP-S301 Player
Toshiba D-VR4 DVD recorder/VCR player
you can get the cleaning disc at any electronic store or even at some other stores like drug stores and even at the dollar store , but if the laser lens is probably to dirty to even see that disc if your player will not even read a music disc, have you tried a music disc? can it read it ? if so the cleaning disc will work.
if not then taking the player apart and manually cleaning the lens will be required
Dec 29, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Problem with dvd player. Trutech 7 inch
I was told that they could reset it but I can not find a number on this company
Mar 20, 2008 | TruTech PVS12701 Portable DVD Player
remove the cover of the unit and try to clean the lens with a soft clean dry cotton swab or if you have a compress air cleaner, just blow it. most of the time cleaning can solved this kind of problem. good luck!
Feb 21, 2008 | Panasonic DVD-S29 DVD Player
Disc cannot be played; please check the disc.
m8 not sure but try the tech sapport on this website http://www.mobilephoneservicecentre.co.uk/
Jul 03, 2007 | Samsung DVD-V5500 DVD Player/VCR
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Samsung BD-UP5000 Blu-ray and HD-DVD Player Logo
236 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
