Question about Hoover F5906-900 Upright Steam Vacuum
Belt on steam vac v2
Do not have manual on hoover steam vac v2 belt recently broken do not know where to start to get to belt
  • 1,673 Answers
The V2 doesn't use a belt, it uses a turbine to drive the brush block, If brushes are not turning, either the shaft on the brush block broke off, or the turbine is bad and will have to be replaced.
Posted on Jan 06, 2008
How do I install the belt on my steam vac V2 model f7210-900
STEAM vac don't have a belt they rotate by turbo motor that sometimes seize up click the link below and watch video how to fix.
Aug 14, 2012 | Hoover F7210-900 SteamVac V2 Upright...
Hoover Steam Vac Instruction Manual
Here is a link that will download a manual. It is for model F7222900 but should work with your machine.
I hope this helps.
Feb 02, 2010 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover Steam Vac V2 Deep Cleaner leaking clean water
Fill the tank and determine if the plastic is leaking, or if the valves are leaking. if the tank is cracked, it would need replaced. There is an improved design now available.
You may cycle the valves on the bottom with the eraser end of a pencil.
Sep 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Where can I get a manual on my model#F5817 steam
Here is a number for customer service for Hoover.
contact our customer service department at 1-800-944-9200 M-F 8 AM - 7 PM EST.
I went to their website and searched for a manual. Some of the manuals will cover more then one model so they will have to tell you which one will work for you. Hope this helps
Aug 15, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Need manual for hoover 6030-900
Hoovers website has downloadable manuals (free i believe) otherwise talk to your local hoover warranty center which you can also lookup on hoover's website.
Best of Luck!
Jun 09, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Belt replacement
No belt- it is motor driven. what happens to these if the rollers get stuck(by- say, a Lego® or something)  is the roller itself has an insert which will break, requiring roller replacement.
simple fix, but costs a little more than a belt. remove two screws holding the roller cover, accessible by flipping the vac over. then figure out which roller is broken, and remove the 2 outer screws on that side. pull the outer bearing cup assembly straight out to remove the rollers.
I have found the rollers as cheap as $3.50 ea/ for generic replacements. Also I reckon any Vac shop would have them on hand.
Mar 24, 2009 | Hoover WindTunnel V2 U8148-900 Upright...
Solution for "the unit is making smoke rubber belt smell how do i change the belt...hoover steam vac f7225-900
there is no belt on this model. From your description, it is definitely electrical, possibly the motor. I would have it looked at a repair shop.
Mar 15, 2009 | Hoover F7225-900 SteamVac V2 Upright...
Hoover Steam Vac
how do i get a manual on how to operate my hoover steam vac dual v spin scrub heated cleaning machine. i bought it used at a flea market and they did not have the manual. can you help me.
Thank you nessa
Oct 11, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
#for hoover steam vav ve with rinse
Here is a link
Or go to, scroll down and on the left click on downloads, enter your model number and a pdf. file will come up that you can download.
Jun 10, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
I have a Hoover Steam Vac V2, model #F7430-900. The spring loaded valve on the soap dispenser needs replacing -is this possible or do I have to get the entire tank. Thanks
Hoover Steam Vac V2, Model #F7430-900
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You cannot replace the spring loaded value on the soap dispenser – it is a whole assembly and would need to replace the entire tank, you can buy them new or sometimes a local vacuum dealer may have a good used one on hand and that would work as well – check the yellow pages for a local vacuum dealer or Hoover dealer for replacement of the part. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 16, 2008 | Vacuums
Hoover F5906-900 Upright Steam Vacuum Logo
347 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
