Question about Aspire Acer 7520-5071 Notebook
Acer aspire 7520g ,turio 64 x 2 TL 58... used to overheat,now i have folowing problem: when starting up, i just get black screen,and on external monitor ia have picture,but it is like colours are melting... in service they chenged graphic card( nvidia 8600 gt) it worked,but problem hapened again. sometimes i start laptop without problems,works perfectly,and then the screen goes black and same problem again...HEEEEELLLLLLLLLLPPPPPP!!!
  • Terrie Henderson May 11, 2010
    Take it back to where you had the card replaced if this was what they did to fix the problem before and it didn't fix it they need to check it out.I had a problem that I was told was caused by a bad card but after I checked in to it was bad memory so I replaced it and it works fine.Its sad but repairs are done on pcs that don't fix problems and people spend more than they need to,because a tec is overconfident or just dose what they did to fix the last pc with a similar problem
    Problem Solver:
  • 14 Answers
Video memory once again, i would say new board but thats too pricey. Maybe invest in a new laptop pal
Posted on Feb 19, 2010
Hi i have got a new keyboard and wish to change it on acer 7520
taken from http://www.batterycentury.com/acer-aspire-7520g-502g25mi-keyboard-p-152819.html
Acer Aspire 7520G-502G25Mi Keyboard Repair and ReplacementAre you considering laptop keyboard repair? You might think twice if you happen to be the lucky owner of a laptop, because replacing the keyboard rather than repairing it could be a lot less expensive. Laptop keyboard replacement on this particular model is very easy and takes just a few minutes. Here is a quick Acer Aspire 7520G-502G25Mi Keyboard repair tutorial with step-by-step instructions. Once you have purchased the new keyboard, all you need to replace the old with the new is a screwdriver and something plastic, flat and thin like a credit card or guitar pick.
Step one: Remove the two screws from the bottom of the computer that are holding down the Acer Aspire 7520G-502G25Mi Keyboard bezel. The bezel is the bar that sits right above all the function keys.
Step two: Turn the computer over, open the cover and insert the credit card or guitar pick between the bezel and the laptop screen. The bezel has pegs that sit in holes, you need to slowly pry up the bezel. It will make a bit of a popping noise as it is removed.
Step three: Now hold on to the laptop keyboard from the end closest to the screen and gently pull it away from the touch-pad end and flip it over. You will see the ribbon attached to the underside of the Acer Aspire 7520G-502G25Mi Keyboard. There is a little plastic connector holding the ribbon to the computer. To unlock it, carefully pull up on the two tabs; one located on each corner of the connector. Be very gentle when you do this as this is the one part that gets broken the most often when changing a keyboard. The ribbon cable will now be released.
Step four: Carefully pull the ribbon out of the connector and remove it along with the entire Acer laptop keyboard.
Final step: To insert the new Acer Aspire 7520G-502G25Mi Keyboard, place the board face down so you have easy access to the ribbon. Make sure the keyboard is lined up so when you flip it back over the keys are in the correct position. Keep the ribbon straight at all times; twisting it could damage it. Place the ribbon in the connector; it only goes in one way. Once in place, push down on the connector tabs to lock it. Now flip the keyboard over and slide it down toward the touch pad and take the bezel and line the pegs up with the holes and push it in place. Then turn the computer over and replace the two screws you removed from the bottom. You can now power on your computer and see if the Acer Aspire 7520G-502G25Mi Keyboard works. If it is not working, more than likely the ribbon was not inserted properly.
May 16, 2011 | Computers & Internet
My Acer Aspire 7520G gives, most of the time, no sound. Problem with the Acer Aspire 7520G 17.0" Laptop Acer Aspire 7520G gives, most of the time, no sound or audio device in windows 7. 2 days ago I...
Try installing the latest audio driver.
Download the drivers from the Acer WEB site. Make sure youselect the model of your laptop and the XP or Vista version of the drivers youthat require and it matches the Windows version that is installed on yourlaptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Feb 18, 2011 | Acer Aspire 7520-5185 Laptop
Want to buy acer laptop, i cant decide what suits me, want it cheaper but still want it best
Cheap Acer Laptop Acer Aspire AS5102WLMi AMD Turion 64 X2 TL-50 1.6GHz
Operating System: Microsoft Windows XP Media Center
Processor: 1.6GHz Turion 64 TL-50
Ram Memory: 512MB
Hard Drive: 100GB
Optical Drive: DVDRW / DVD-RAM
Display Screen: 15.4" WXGA display 1280 x 8004352b29.jpg
Oct 25, 2010 | Acer Computers & Internet
My acer aspire one will not start up. message
YOU WILL HAVE TO REPAIR YOUR WINDOWS INSTALLATION USING WINDOWS BOOTABLE INSTALLATION CD/DVD.
Apr 09, 2010 | Acer Aspire One PC Notebook
Keyboard Replacement Instructions for Acer Aspire 7520g
if ur key board is guranty period than ur keyboard is replacement by service center oterwise warrnty period only repaired by service center.thank u
Jun 03, 2009 | Computers & Internet
Can i upgrade my processor from 1.9ghz to 2.8ghz?
According to Acer's website sepcifications, that Laptop is only upgradeable to 2.3GHz:
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=606&formid=3404&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
AMD Turion 64 X2 dual-core mobile technology TL-66/TL-64/TL-60/TL-58/TL-56 TL-52 (2x 512 MB L2 cache, 2.30/2.20/2/1.90/1.80/1.60 GHz, 1600 MHz HyperTransport Bus),
AMD Turion 64 mobile technology MK-36/MK-38 (512 KB L2 cache, 2/2.20 GHz,), supporting AMD PowerNow! technology and AMD HyperTransport technology or
AMD Athlon 64 X2 dual-core mobile technology TK-53/TK-55 (2x 256 KB L2 cache, 1.70/1.80 GHz), supporting AMD PowerNow! technology and AMD HyperTransport technology
Apr 17, 2009 | Acer Aspire 4520 Notebook PC
Nb acer aspire 7520G - black screen (no light) on startup - starting from sleep mode
Pull the battery and unplug it.
Plug in the AC adapter and see if it boots.
if it does shut it down and reinsert battery, problem solved.
if that doesnt do it then i would check that your ram is seated properly and try swapped between 2 ram chips in both sockets (if your laptop has 2 sockets.
Hope this helps!
Nov 28, 2007 | IBM ThinkPad T20 2647 Notebook
Aspire Acer 7520-5071 Notebook Logo
435 people viewed this question
Top Aspire Computers & Internet Experts
pankaj rautela
pankaj rautela
Jax Planet
Jax Planet
EKASYS IT SERVICES
EKASYS IT SERVICES
Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
