Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
What size bolt fits in the bottom of the crankshaft to hold up dbl, pully ? would that be a 7/16 -20 thread? crank size 1" if so,,what would the lenth of that be and the washer size and thickness???? Robert
  • 437 Answers
If this is a Craftsman riding mower. You can go to partsdirect.com; this is Sears website. Put your model number in and find the diagram along with
a parts list.
Posted on Oct 06, 2009
1997 corolla crank pully bolt thread (left hand thread?)
it will be a normal RH thread. For easy removal use a 1/2 drive rattle gun and you will not have to try and hold the crank while you are undoing the bolt.
Apr 04, 2014 | Toyota Corolla Cars & Trucks
I need to replace my timing belt on my hyundia elantra 2003 with 1997 cc engine
Dear Friend
Removal: Support engine: remove -engine mounting, auxiliary drive belt, water pump pulley, crankshaft pully bots & crankshaft pully, timing belt covers....turn crankshaft to TDC on No 1 cylinder, ensure crankshaft sprocket, camshaft sprocket, oil pump sprocket & balancer shaft sprocket timing marks lighned. Pls note: Timing marks on camshaft sprockets should align with cylinder head uppter face, dowl pins on camshaft sprockets should face downwards....Slacken tensioner botl. Move tensioner away from belt & tighten bolt.
Remove: automatic tensioner unit bolts, automatic tensioner unit, timing belt, crankshaft bolt, crankshaft sprocket, crankshaft sprocket guide washer...slacken balancer shaft belt rensioner bolt, move tensioner away from belt & lightly tighten bolt...Remove balancer shaft belt.
Installation:
ensure timeing marks aligned.Note: Timing marks on camshaft sprockets ahould align with cylinder head upper face, exhaust sprocket mark is on recess but inlet sprocket mark is on tooth. To check oil pump sprocket positionded sorrectly: remove blanking plug from cylinder block, insert 8mm diameter Phillips screwdriver in hole. ensure screwdriver is inserded 60mm from face of cylinder block. If screwdriveer can only be inserted 20mm-turn oil pump sprocket 360". Inset screwdiver again.
Fit balancer shaft delt in anti-clockwise direction starting at crandkshaft sprocket....Slacken balancer shaft belt tensioner notl, turn tensioner clockwise to tension belt. Tighten bolt to 15-22 Nm... Applu thump pressure to belt at tentioner, belt should deflect 5-7mm. If not: Repeat tensioning procedure.... Install - chankshaft sprocket guide washer & crankshaft sprocket.
Thighten crankshaft centre bolt, tightening torque:110-130Nm. Please note, ensure crankshaft sprocket guide washer is fittet correctly. oil threads & contact face crankshaft botl before fitting.
Sep 21, 2009 | Hyundai Elantra Cars & Trucks
My pulley from the crankshaft came off, it might be a stupid question, but did it break or just come off?? 1999 Mercury Grand Marquis
Not a stupid question. If thedampener is not tightened down sufficietly., The bolt can work itself out over tine.Without the clamping effect of the bolt the hub is able or will react to the crank shaft rotation pulses.which the dampener is supposed to absorb. Enough vibration,rotation counterin stress and eventually shears the keyin the crank and the dampener hub starts slipping on the crank . The rest is a given, the more it moves the more it loosens untilit no longer holds, Then you end up ssking this question. If you have lost a dampener, Just installing a new one will more than likely be futile.. The crank is now worn down and there will not be adequate sizing for the interference fit.. If you clean up the crank, and use loctite red on the pully and crank surfaces making sure the bolt is tightened real good with loctite thread lock on the threads, you mjust might get away with it. I can't see the dmage so you make the call. Now is you chance to replace the front crank seal. Is it in the shop now?
Sep 17, 2009 | 1999 Mercury Grand Marquis
Daewoo Matiz crankshaft pulley
remove the outer small bolts to remove balancer(pulley) the big centre bolt holds crankshaft gear for timming belt which slides off with timming belt removed.
Sep 10, 2009 | Daewoo Nubira Cars & Trucks
Remove bolt on crank ram 1500 360 engine 1995
The bolt holding the pully on the crankshaft is normal thread, so you turn it CCW to remove.
But you will need someone to lock the crankshaft from turning, by putting a bar into the flywheel teeth. If there is no opening, you can make one by taking out the starter.
Jul 25, 2009 | 1998 Dodge Ram 1500 4WD
How to remove bottom pully bolt 1.6 hdi 307
you need to peg the crankshaft near your gearbox. There is a hole in engine block for this purpose. Find this hole and insert an allen key (thick enough to fit in there). Turn the crank pully with ratchet in clockwise while try to find out the locking hole in crankshaft near gearbox by pushing allen key through engine block hole. You'll hear a click and the allen key goes fully inside. Now your crankshaft is locked and you can open (anticlockwise) the pully bolt.
Jun 01, 2009 | 2006 Peugeot 405
Is the bolt on the crankshaft pully right or left hand threads?
The crank pulley bolt on most Honda engines are very difficult to loosen. Most 1/2" impact guns are just are not strong enough to loosen them. The choice is yours to either use a 3/4" impact gun, the bolt is left losey, righty tighte
May 30, 2009 | 2002 Honda Odyssey
HOW TO REMOVE BOLT FROM PULLY ON CRANK PULLY
They are usually in there pretty tight. If drivable, you can have someone loosen it up with a shop air gun.
Thread is not reverse.
There is a second way to remove it...Use a solid 1/2" breaker bar with the correct size impact socket. You need to support it and brace it against the floor. Then "bump" the engine over Don't crank, just bump. The engine crank will unscrew itself from the bolt. Be careful doing this if socket and bar get loose they can damage you and stuff around the area where you're working. I use a pipe driven into the ground with a pair of vise grips attached to the breaker bar to keep it at the right height. (bar goes inside the end of the pipe)
Apr 20, 2009 | Oldsmobile Aurora Cars & Trucks
FOR FIXING THE CRANK SHAFT PULLY WHICH BOLT IS FIX SMALL OR BIG
The large bolt holds on the lower crankshaft pulley for timing belt, the six small bolts hold the larger pulley that drive the alternator, power steering etc. It sounds correct.
Dec 04, 2008 | 2001 Kia Sportage
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
75 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
