Question about Honda Garden
Engine starts then cuts off after a few seconds
    Problem Solver:
  • 8 Answers
SI ES CON MOTOR A GASOLINA PUEDE ESTAR ENTRANDO EL SENSOR POR FALTA DE ACEITE O PUEDE ESTAR TAPADO EL CARBURADOR
Posted on Oct 06, 2009
What causes engine to cut out?
Maybe your coil pack. It can overheat and short out. Then it cools down and will work for a while till hot again.Could also be spark plugs and wires.
Feb 12, 2016 | 1999 Honda CR-V
What causes no pulse to injectors?
Hi there can be a few things
1)Faulthy crank/cam position sensor
2)on diesel engine can be faulthy rail presure sensor cutting all 5v components
3)Broken off wiring
4)Ecu (engine control unit) Faulthy
Sep 18, 2015 | Cars & Trucks
Plug code reader
Your car went into back up mode. this is usually a serious engine problem or just bad gas.
Apr 20, 2014 | 2006 Chevrolet Corvette
Grinding noise when starting '98 Izuzu Rodeo
Upload video please then i might have a better idea
Jul 15, 2013 | Cars & Trucks
My car start for a few seconds then cut of with engine light coming on. Then when I try to start it again it wont start at all. The only way to start it again is to switch car off. Lock then unlock car,...
There seems to be an lurking error that comes into the ECU/ECM and so it prevents the engine to run as this seems to be a protection for further damage or prevention.
So you need to check the input parameters to the ECM , check the engine oil,oil filters the fuel filters and the oil pressure switch. The check engine light code must be confirmed and identifed to recitify the fault. Please take consensus with the service center before you finalise the fault.
Sep 06, 2011 | 2004 Mazda 3
The engine cut out then right away was running again then 20-30 seconds later completly cut out again. After a few minutes it started again and ran for another two days. Then it cut out again, ran for...
- When was the last time this car had a tune-up? Could be as simple as that. New spark plugs/rotor/distributor cap/condenser might do the trick.
Other causes could be:
- bad fuel pump relay (definitely first on the list of things to check, and cheapest to fix)
- clogged/old fuel filter
- bad fuel pump
Mar 01, 2011 | 1991 Honda Civic
Bmw m62 engine shurreding and trying to cut off?
It sounds like an inlet manifold seal. Try to rev the engine up to about 1500 revs, if it runs ok, then it's either that or your air-flow mass meter
Jan 17, 2010 | 2008 BMW 535i Sedan
Idle engine cuts out
You need to get to the idle screw on your carb and srew it in until your idle raises up a bit, also put some Techroline (chevron) in your gas tank...1/2 bottle in Full tank.....Good luck to you friend....Tim
May 12, 2009 | 2003 Suzuki UH 125 Burgman
Garden Logo
116 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
