Question about Brother HL-2170W Laser Printer
HOW DO I TURN ON THE WIRELESS ON HL 2170W FROM
HOW DO I TURN ON THE WIRELESS ON BROTHER
HL- 2170W FROM INACTIVE TO ACTIVE
Joed911
  • 4338 Answers
SOURCE: Brother hl-2170W wireless problem
Reset the network print server back to factory defaults:
Turn off the printer
Make sure the front cover is closed and the power cord plugged in.
Hold the "GO" as you turn on the power switch. Keep the GO button pressed down until the Toner,Drum,Error LEDS light up. Release the GO button. Make sure that the Toner,Drum,and paperLEDS are off.
Press the GO button seven times. Make sure that all the LEDS light up to indicate the print server has been reset to factory defaults.
Then setup the IP address.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 07, 2008
Joed911
  • 4338 Answers
SOURCE: Corona wire problems
Read the following links:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002500/000026/faq002526_000.html?reg=us&c=us&lang=en&prod=hl2170w_all&Cat=7
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000008/faq000208_021.html?reg=us&c=us&lang=en&prod=hl2170w_all&Cat=7
copy and paste the complete link into your browser.
Thanks, Joe
Posted on Nov 30, 2008
  • 5 Answers
SOURCE: Brother HL-2170W Laser Printer is 'offline" wont turn back online
On Windows XP the solution is as follows. Do the install per directions using the network cable method. Install BRAdmin light off the setup disk. ( password=access)Then, get into Printers And Faxes via the the Start->Settings method and DELETE the printer then (you will need the IP address of the printer, it will be something like 192.168.2.3) For Windows® 2000/XP and Windows Server® 2003 8
In Printers.& FAXES
Click Add a printer to start the Add Printer Wizard.
For Windows® 2000: Double click the Add Printer icon to start the Add Printer Wizard.
c Click Next when you see the Welcome to the Add Printer Wizard screen.
d Select Local printer and deselect the Automatically detect and install my Plug and Play printer
option, then click Next.
e You must now select the correct Network printing port. Select Create a new port and select
Standard TCP/IP Port from the pull-down window, then click Next.
f The Add Standard TCP/IP Printer Port Wizard will now appear. Click Next.
g Enter the IP address, or the node name you wish to configure. The Wizard will automatically enter the
Port name information for you, then click Next.
h Windows® 2000/XP and Windows Server® 2003 will now contact the printer that you specified. If you did
not specify the correct IP address or name then an error dialog will appear.
i Click Finish to complete the Wizard.
http://www.brother-usa.com/ModelDocuments/Consumer/Network%20Users%20Manual/NUM_HL_2170W_EN_1292.PDF
Posted on Jan 21, 2009
SOURCE: Error Light on Brother HL-2170W
Do not try to depress the green lever, since you need to remove the cartridge AND its base altogether. Just grab the front middle part of the assembly, pull it out slowly and steadily. You may need to apply extra force in doing so as it does take some effort to disengage the cartridge assemly from its seated position.
After the cartridge is removed, you may find some jamed paper inside. simply remove it and the printer should work again.
You may email me at stevenjoy@gmail.com should you have further questions.
Posted on May 21, 2009
  • 11 Answers
SOURCE: Remove toner catridge from Brother 2170W
Open the front of the face. Pull out the catridge and drum assembly carefully. Thier should be a yellow tab on the toner catridge press down and the lift the toner catridge out. Replace and reseat in printer.
Posted on Sep 09, 2009
Brother HL-2170W printer is plugged in and will not turn on.
How old is this printer?
Have you tried another power outlet? If, so are any lights emitting from the device?
May 03, 2011 | Brother HL-2170W Laser Printer
I changed my wireless password now my brother HL-2170W Laser Printer isn't working can you tell me how to tell the printer the new password?
look in your user manual on the proper procedure. if you don't have the manual go to brother.com and download it. you can also ask a question on the site and they could also be able to help you.
Feb 19, 2011 | Brother HL-2170W Laser Printer
2170w not able to use wireless
Hi there
Yes you can buy parts on the internet or at a computer shop to add on to make it for wireless.
All the Best Pineworks
Apr 28, 2010 | Brother HL-2170W Laser Printer
I installed a Brother HL-2170W a month ago and it worked fine on my wireless. Now I cannot get a wireless connection. Can you point me in a direction?
Please check that, can you go online with any wireless computer,if you can go online with that, then try to reconnect your wireless printer again (if can't go online then check wireless router)
Hope it can resolve your query
Thanks for using Fixya
Apr 03, 2010 | Brother HL-2170W Laser Printer
Why is HL 2170W printer saying it is offline. It is wireless and I used Netgear
Go to the computer Control Panel, select Printers, right mouse click on the printer and choose Use Printer Online. See what happens.
Mar 16, 2010 | Brother HL-2170W Laser Printer
Brother 2170W "fails to associate"
Have you tried the SecureEasySetup method of connecting your HL-2170W to your wireless network?
Basically, it involves no wires:
1) Press the wireless setup button on the back of your printer (you may need to use a pen or pointed object)
2) Press the SecureEasySetup button on your router
3) Let the two sort it out - Green Go button on printer indicates success.
A complete guide for using the SecureEasySetup for your brother model:
Brother SecureEasySetup Method
I hope this helps!
Jan 26, 2010 | Brother HL-2170W Mono Laser Printer
I am unable to setup the wireless feature for my Brother 2170W laser printer. Any thoughts?
http://download.brother.com/welcome/doc002311/cv_hl2170w_eng_nug_A.pdf ,<- is the link to the manual which explains in details how to configure the printer to connect to the wireless and how to install the printer on the computer.
Jan 23, 2010 | Brother HL-2170W Laser Printer
Lost cd-rom for brother HL-2170W. I need to connect a new laptop to the printer on my wireless network and can't figure out how to do it! It's running Windows XP Pro.
Download the updated firmware, drivers and software for you printer from here (select 'ALL' as Type, and then select your OS and language, to see all downloads available in one page):
Brother HL-2170W downloads Homepage
Also download the manual and guides for your printer:
Brother HL-2170W manuals
And make sure you also look through the FAQs and Troubleshooting under 'Initial Setup' and 'Software' sections:
Bother HL-2170W FAQs & troubleshooting
Sep 02, 2009 | Brother HL-2170W Laser Printer
Cannot print to 2170W via wireless
You need to hard coat your Ip for the printer.
Aug 29, 2009 | Brother HL-2170W Laser Printer
Hl-2170w brother is offline
I just realized what my problem was with this same situation..."Off line". Do the following:
1. Reset the printer to factory default settings: turn off, turn on holding down blue button; after all LEDs light-up release button; All LEDs with go out then flash once.
2. Hook up the printer to an open port on your wireless HUB.
3. Install Brother software (note: go to programs/brother HL-2170 and select remove software prior to reinstalling)
4. Here is the catch: MAKE sure to select the correct encryption code. I was selecting TKIP instead of AES and two things happened...1) the computer did not pick up the printer on the network scan, and 2) the printer will remain off-line.
Once i selected AES, the computer found the printer on the network and viola' no more problems.
I then added my wireless laptop: installed drivers only, the programs scanned and found the printer on the wireless network and that was it. Now both computers are wireless!
HOPE THIS HELPS!!!
Jan 21, 2009 | Brother HL-2170W Laser Printer
Brother HL-2170W Laser Printer Logo
488 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
