Question about Toshiba Satellite A45-S150 Notebook
Ide error #1 a45-s150 at start up my toshiba cause I replace the orginal cd for a diferent brand and gives me problem slave master....etc.. so after thinking in everything updating bios etc... I gUESS THE SOLUTIOS HOULD BE TO WELD SOM PINS INSIDE THE NEW CD/DVD BUT MY QUESTION IS WICH ONES ????? OUT OF THE IDE CONECTOR ???
    President:
  • 2,600 Answers
Go to the BIOS screen....F2 at the splash screen. See if the new dvd drive is showing up in the BIOS and what interface is it listed under. It may be listed under an interface that has not been anable in the BIOS, highlight the device or interface, hit enable and then hit F10 to save and reboot.
Posted on Oct 06, 2009
What is the position of the link do I need to change to master/ slave etc
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
The BIOS is AMI. Under ADVANCED SETUP:
? single or master :::::
master with slave ::'::
???????????????? slave? :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
hope this helps
Jan 28, 2011 | BenQ CRW-5232W 52X32X52 IDE CD-ReWriter...
Shows #1 IDE error on start
This is a BIOS Fatal Error. This is not an error which comes occasionally and without a reason. Did you change anything. A CD/DVD Drive or something like it. If yes the problem is here. You must have got the Jumper on the Rom wrongly. There are 2 options MASTER and SLAVE. You must applied the Slave option which is causing it. You need to take it to Toshiba, they will reset the Drive and the Bios.
Thank you, Have a nice day.
Sep 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
Application error 437 - cannot read file 17274 bluesky.wmz This is first time I have tried to use the Toshiba recovery disk for my Satellite A45-S250. The installation repeatedly fails with the above error...
check the cd you are using for scratches, looks like a readom the cd error to me.
to solve:
copy cd using freeware program: imageburn,make an image of disk, burn it onto cd-r(your save-copy, legal)
try installing from copied version could work
else:
copy whole installation cd into sepearate folder and run installation from harddisk.
Jun 17, 2009 | Toshiba Satellite A45-S150 Notebook
Windows XP will not start
Then you will have to reinstall using you backup disks.If that doesn't not work replace the hard driver then reinstall using the backup disks..
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=713852&rpn=PSA60U&modelFilter=A45-S150&selCategory=3&selFamily=1073768663&selModel=713852|PSA60U
Mar 15, 2009 | Toshiba A45-S150 Notebook
Pioneer dvd-rw dvr-k17a
Are these drives you have fitted yourself, or been added as after market drives?
If so you have run in to the odd way Toshiba set their optical drives as master or slave, although this is generally and IDE #1 error.
To fix this you need to solder pin 45 and 47 together.
47 is the key pin here, as it controls whether the drive is in SLAVE or MASTER mode.
grounded, the drive is in MASTER, open, it is in SLAVE.
pin 45 is simply a grounding pin.
So you'll need to open up the drive, turn it over, and put a small blob of solder on the two pins next to each other - 45 and 47.
If they are original drives or used to work then uninstall the drives and the IDE controllers in Device manager and reboot, letting windows redetect and install the hardware. Also try reinstalling the motherboard drivers available from Toshiba's support site.
Oct 08, 2008 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Replacing the cooling fan
You can find a guide with pictures there:
http://www.irisvista.com/tech/laptops/ToshibaA45/Satellite-A45-remove-hinges-1.htm
The guide is for display hinge, but you can follow until step 20 and the rest should be easier!
Aug 25, 2008 | Toshiba Satellite A45-S150 Notebook
I need recovery disc
I do have a satellite a45- s150 laptop I can make a set of copies for recovery cd's if u need 'em
May 29, 2008 | Toshiba Satellite A45-S150 Notebook
Toshiba Satellite A45-S150 Notebook Logo
213 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
