Question about Dell Latitude D600 Notebook
CD/DVD tray will not stay closed - Dell Latitude D600 Notebook
    President:
  • 2,600 Answers
If you push the tray closed and it simply springs back out, then the internal latch is either jambed open or broken off. Open a paperclip and push an end into the black hole you see on the door bezel. push gently in the hole, you feel the clip contact the release mechanism. You may have to push on it several times to see if it can be dislodged (if it's not broken), if the door is still popping open, you may have to change out your drive.
Posted on Oct 06, 2009
The cover for the DVD/CD does not stay closed
The belt that turns pulley to open and close dvd tray is probably worn out
May 02, 2015 | Televison & Video
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
My cd tray wont stay closed. it opens a few secons after i close it.
Don't worry dear user this problem is creates when we using a long time are cd/dvd writer but if have this type problem please reinstall your cd/dvd driver and your problem can be solved........
Jul 04, 2011 | Dell Studio 15 Laptop
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
THE DVD TRAY KEEPS OPENING
check if the power hubs on the back of the back of the drive are hooked up right if they are un hook and hook back up while your pc is off
Mar 13, 2009 | LG GSA-H55N DVD-RAM Burner
Cd tray will not stay closed it opens as soon as you close it
Hi and welcome to FixYa,
Offhand, 3 possibilities:
  • tray is not really reaching closed position, belt is loose/worn out (most likely), replacement required;
  • dirt on the laser/optics, false reading, the CD is thinking it has a CD inserted and when it can not read, it ejects. Clean with a CD disc cleaner (likely);
  • virus/malicious software (a possibility), scan/clean.
Good luck and Thank you for using FixYa.
Jan 05, 2009 | iLO DVDR05 DVD Recorder
Cd/dvd drive won't stay shut
I have the dv9000z. If I do NOT push the DVD drive tray all the way in until it CLICKS shut, then it OPENS again after 1-2 seconds. This is normal. I have found that most times when I close the DVD tray drive, I am not pushing it in far enough, because the top of the DVD tray is rubbing against the laptop's case. If I just press down VERY SLIGHTLY and push the DVD tray in, the tray will fully close and CLICK shut. This works for me. Good luck.
Jun 30, 2008 | HP Pavilion dv9000z Notebook
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
LG DVD+RW door won´t close
Deliverance
this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
Dec 19, 2006 | LG (GSA-4120BK) DVD±RW Burner
CD tray opens and won't stay closed for burning
Sounds like an issue with the contact behind the button on the drive. How old is the drive? Replacements are cheap these days.
Sep 04, 2006 | HP (dw381a) CD-RW/DVD-ROM (Combo) Burner
Dell Latitude D600 Notebook Logo
263 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
