Question about Microsoft Wireless Optical Desktop Comfort Edition
MS Wireless Desktop set - KB and Mouse
When I boot the PC, it stops at POST and says keyboard error or no keyboard present. I then press the button on the transmitter, depress the button on the back of the KB, turn off the PC and turn it back on and it works. Never have a problem with the mouse although at the fail point the mouse doesn't come in to play. This is baffling as I have reinstalled the software and uninstalled and reinstalled updated software and have changed USB ports - frustrating. Running XP Pro with 64-bit AMD CPU and 1 gb RAM. Any ideas???
Webbsk8r@yahoo.com Dave
  • 35 Answers
Well this problem has nothing to do with your Operating System. This has everything to do with your System Bios.
Basically, the first thing you need to determine is "Is it USB or PS2?"
If it's USB:
1) Is it installed in a USB Hub? It might not have enough power, try a different USB port.
2) Go into the system bios. Look for an option that says "Enable USB Support" make sure it's enabled.
If it's PS2:
1) The connection might be lose, turn the computer off, unplug it, plug it back in.
2) Try a different PS2 Keyboard, same problem? Your PS2 ports are failing, buy a USB Keyboard.
Posted on Oct 24, 2008
My gateway wireless mouse won't sync
- Have you tried the steps mentioned in the link to connect a wireless keyboard and mouse to the Gateway computer? http://support.gateway.com/s/desktop/2009/gateway/zx/zx4800/ZX4800faq3.shtml
http://www.support.gateway.com/s/Manuals/Profile/WirelessKb_MouseGuide.pdf
Also follow the generic troubleshooting steps mentioned in the link to connect a wireless keyboard and mouse to a computer.
http://support.microsoft.com/kb/838398
Note: The steps provided in the link mainly works for Microsoft hardware but the steps can be applied to any wireless keyboard and mouse. Do not install any software given in the link as it will not help you if you do not have a Microsoft Hardware.
It would be helpful if you could provide us the exact computer model number and also the make and model number of the keyboard and mouse.
Feb 14, 2015 | Gateway GM5664 Desktop PC
My Acer Aspire Z5600 at booting not reading the wireless keyboard and mouse, it's booting but as keyboard is not connecting, I am unable to type my password and get stuck at password screen. Have
try resetting the BIOS to defaults. Also, make sure the wireless KB and Mouse works by testing it in another PC. Acer might be aware of this issue, so try calling them if those ideas do not help.
Sep 21, 2012 | Acer Aspire Z5600 PC Desktop
MY KEYBOARD AND MOUSE HAVE BOTH STOPPED WORKING. I HAVE THE KENSINGTON PILOTBOARD LASER DESKTOP SET. # 64390. I HAVE PLUGGED IN A WIRED SET BUT I MISS MY WIRELESS !!!! CAN YOU HELP ME? I HAVE CHANGED THE...
If the power cells are new, both the keyboard and mouse are powered correctly (Battery I assume are positioned correctly). If Neither one operates, then check the small dongle that fits into the USB port. It may have been loosened, and if so just pull it from the port and reinsert it in another port. If still no connection, then the dongle may have burned out. The problem: Once a dongle is spent, the entire set is useless as they operated on an audio signal (Frequency) set for that mouse/keyboard. No replacements.
Jan 31, 2018 | ACCO Brands Kensington PilotBoard 64390...
Ms 8000 mouse pairing code
You choose your own code. It's a keyboard right? So it has numbers on it...and an Enter key.
1. Press and hold in the small button next to Bluetooth symbol under the keyboard for 5 seconds. The charge indicator lights at the top of the keyboard should alternate flashing red then green.
2. Search for Bluetooth devices on the devices you wish to connect the keyboard to. The Keyboard should be listed there.
3. Enter a code of your choice into the device you are paring the keyboard to and submit it. I used a 4 digit number which worked without a problem.
4. Type the same code and press Enter on the Microsoft Wireless Entertainment Desktop 8000 Keyboard.
The keyboard should now be paired with your device.
Good luck, - GregAndo
Jan 29, 2010 | Microsoft Wireless Entertainment 8000...
Dell dimension 2350 cpu fan failure
i can help with the mouse & keyboard.
go into the bios on boot screen you press DEL i think then activate the USB mouse & keyboard option then save & exit.
there will be settings for the cpu fan in there somewhere but i can't remember where sorry.
Aug 16, 2009 | Dell Dimension 2350 PC Desktop
Can I use a new MS wireless mouse to replace my existing MS wireless mouse. Currently my mouse and keyboard connect together on the same wireless USB device. Could the new mouse be detected and be used...
I suppose there is a reset button on the keyboard or the software provided so I suppose it could be possible, I don't know.
I use a Microsoft Wired Keyboard...
But Best of luck.
Jul 21, 2009 | Microsoft Wireless Optical Desktop Pro +...
Microsoft Wireless Keyboard 5000 keeps opening and closing the windows start menu once connected
Did you try the following.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Oct 26, 2008 | Microsoft Wireless Optical Desktop 5000...
Microsoft Wireless Laser Desktop 4000, can't use mouse and keyboard simultaniously.
I was playing UT2004 and using the w key it would stop working too puzzled me for days but never figured it out....and now ive ran out of time to play lately so i dont know whats up with it but i have the same keyboard and mouse set and it just seems that this whole set is full of bugs!
Jan 02, 2008 | Microsoft Wireless Laser Desktop 4000...
Microsoft Wireless Optical Desktop Comfort Edition Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
