Question about Linksys Wireless-N WRT150N Router
IP-address to my linksys WRT150N (192.168.1.1) doesn't responde any more. Does it men, that my router is finished or what else can I do? With best regards Tadeusz Sienkiewicz
    Genius:
  • 1,269 Answers
If the router's IP doesn't respond, you can simply do a hard reset. Press and hold the reset button at the back of the router for 30 seconds then unplug the power. Wait for 30 seconds before you plug it back in. Try to check again if the IP will going to reply. You might as well try to restart your pc after doing the hard reset.
Posted on Oct 06, 2009
The connection to 192.168.1.1 was interrupted.
Posted on Jun 13, 2012
  • tomcence
    tomcence Jun 13, 2012
Linksys wireless N WRT150N Router showing limited or not connectivity
Hi.
If you have a cable modem or DSL modem, try to unplug power on it and your router too. Then plug the power back to the modem and wait until you see almost all the lights on. If your unsure just wait about 1 min and it should be ok. Next plug power back to your router. This will create an new IP address which could resolve your problem.
Feb 08, 2011 | Linksys Wireless-N WRT150N Router
How do I Access the router’s web-based setup page?
Hello
you need to know the routers ip address or have the software. For most things the ip address will be 192.168.1.1 . You simply type that in your web browser and a page will come up.
you may need to go to the linksys site to find the default ip address of your router. But I would try "192.168.1.1" first.
Have a great day
Nov 25, 2010 | Linksys Wireless-N WRT150N Router
I can not change router ip
You need to change the router's IP to avoid conflict with the modem's IP address. You just need to access the router's setup page , default is 192.168.1.1. Default username should be left blank and default password is admin. Once logged in , first page you will see is the Basic Setup page. Just look on themiddle part of this page and there you will see the IP address of the router. Most of the time, if the user has DSL connection , Linksys' IP should be changed to 192.168.2.1. Dont forget to click on Save Settings at the bottom of the page. It will then say Settings are successful. Now click on continue. You can then power off then power back on the router for the changes to apply
May 15, 2010 | Linksys Wireless-N WRT150N Router
Re-installling wrt150n router to new computer.
ask you ISP what are the IP address and DNS server address that you need to feed in the properties setting of the TCP/IP setting in the Network Connection wizard in Control Panel
without these the connection will not work
Dec 09, 2009 | Linksys Wireless-N WRT150N Router
I am installing my new wrt150n router and no internet
Turn off modem and router. Connect router to computer. Turn router on. Connect router to modem. Power up modem. When it discovers the modem it will assign to it the new IP address.
Hope it helps.
Sep 25, 2009 | Linksys Wireless-N WRT150N Router
Problem with VPNand Linksys router WRT150N
If that is the case you may forward ports on the router for VPN connection, try to open 47, 500 and 1723 all TCP and UDP protocol.
Here's what you need to do, check the IP address of the computer where you have the VPN software,
here's how:
click start> run> type cmd> hit okay
on the black screen put in ipconfig and check the IP address there,
> when you get the IP address then we can enable port forwarding on the router
> open IE on the working computer on the address bar, type 192.168.1.1
> nothing for username and password is admin in lower case
> then click on the applications and gaming tab on the router,
> and from there, example of how to field that in is like this,
> for aaplication name - VPN1
> for port it is 47 to 47
> for protocol it is BOTH
> for IP address ex. 192.168.1.XX - 192.168.1.100
> then check enable, do the same thing for the rest of the port.
> save the settings and try it again after.
> if it is still nothing, you may connect the computer that has the VPN connection directly to the modem and check if you will be able to connect via VPN
i'll wait for your response, thank you and have a nice day!
Jul 14, 2009 | Linksys Wireless-N WRT150N Router
Trying to hook up a links wrt150n to terby net
Step 1. Connect your computer to the router. Did it get an IP address? If so, try to browse to the IP address of the default gateway. If not reset the router configuration (see below:)
Step 2. There should be a small hole in the back of the router. Turn off the power, stick the end of a paperclip into the small hole to depress the reset button, hold down the button while you power the router back on, wait a minute then take the paper clip back out.
Step 3. The router should now be reset with the initial configuration, retry step 1.
Jun 05, 2009 | Linksys Wireless-N WRT150N Router
Whats my router ip address
This routers default ip address is 192.168.1.1 no username and password is admin..
Hope that helps........
Aug 20, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
2,396 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
