When I boot my computer, it says ''Bios not installed.'' How do I install it?
    Problem Solver:
  • 5 Answers
Hi friend . ..
this is a small prob .. just open your cpu cabinet
then just look around there is a cell . . a small cell battery just clean and put it back in his place . ..
2. check the rame . . and clean it. . and put it back . .
now just see wheather your pc starts or still going with prblem , ,, ,
if there stil not working then just format it and your problem will solved . .
Posted on Oct 06, 2009
How to install windows xp to psrd1-vm mother board
if you want to install xp to your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Jul 03, 2011 | ASUS P5RD1-VM Motherboard
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
I can't boot up. it display error 2100: Hard disk drive initialzation error.
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive.
Try this:
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Boot from either your emergency repair disk, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
If the above fails:
Verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
If all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Let us know how it works out.
Jan 11, 2011 | Lenovo T410 Notebook
How to reinstall windows XP
If your computer boots up you should be able to reinstall with your xp os disk, click on your cd drive & choose reinstall or new install, after that you'll probably have to go to windows update & update the system, if that does'nt work you may have to go to bios settings & set the cd rom as your boot devise, restart & install that way, after your done be sure to set the bios to thier default settings.
Dec 07, 2010 | Computers & Internet
How do I reboot with our a disc, please and thank you
Power on the computer.
Put the disk in the optical drive.
When asked there are two options.
A) Repair (Non-Destructive Installation)
B) Full Installation (Destructive Installation)
If you do Not wish to keep your personal documents on your computer, use Full Installation.
It will take your computer back to Day 1 when it came from the factory.
If you wish to keep your personal documents,
(Pictures, Videos, Music, documents you have created, or downloaded, programs you have installed, or downloaded from a website),
then click on Repair.
IF, upon starting your computer, and installing the Restoration Disk in the optical drive, (And closing the optical drive tray), does Not work, please post back in a Comment.
You'll have to go into BIOS Setup, and in Boot Options set the first boot device to CDROM.
(Doesn't matter if you have a CD or DVD optical drive. To include a burner version)
This will force the computer to boot off of the disk in the optical drive.
Oct 22, 2010 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Unable to install XP OS to MSI lap top
Insert your installer to the lap top then try to change the boot up priority by entering the bios. Try to press del key while your lap top boot. If these deosn't wok try F1 or F2 thesame process. If you have enter the BIOS, look for the boot priority which includes the First Boot, 2nd Boot and 3rd boot. Change the 1st boot to CDROM and the 2nd boot to hardisk. Then save the changes by pressing F10. your PC will reboot and it will direct you to the OS installation.
Mar 29, 2010 | Computers & Internet
Bios replacing
You will need to download the BIOS installation software for DOS if they have one from the motherboard manufacturer and the BIOS file. You will then need to make a bootable dos cd-r disc using windows. Once you have done this you can use the disc to start your computer in DOS mode. Then burn the BIOS DOS SOFTWARE and the BIOS FILE on a cd-r. Then you will be able to run the BIOS software from dos and install the bios file. You could also install windows on a USB hard drive then try to boot from it if your computer can boot from USB and the USB boot device option is still working.
Nov 26, 2009 | ASUS A8V-E SE Motherboard
I can't install xp instead of vista in my pc compaq presario cq 60 116EM
How are you trying to install? It may not let you do it through windows you will have to boot from cd and format your hard drive to complete the installation.
Oct 19, 2009 | Compaq Presario Notebook
Installing XP on a vista pre-installed laptop
your harddisk is not detected in bios.reconnect your harddisk power cable and sata or ide cable again.then check in bios harddisk is detect or not.
u cna enter in bios with "del" key when u power up ther computer prerss "del" or F2 keyh to enter in bios.
Mar 25, 2009 | Acer Aspire 3680 Laptop
Emachine boots to bios with a new hard drive installed
Go inside to your BIOS menu then set the BOOT sequence to CD as the first boot so when your PC with the operating system installation disk inside it will load the installation wizard.
Good luck hope that helps........
Jun 16, 2008 | E-Machines eMachines T3830 PC Desktop
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
