Question about GE Ovens
JTP13GV wall oven getting F3 code - GE Ovens
  • blopez986 Oct 06, 2009
    Checked connections between temp sensor and board and it is well seated.
    Checked resistance on temp sensor,
    it reads the proper 1100 ohms from lead to lead
    it reads the proper infinite ohms from each lead to ground.
    From the diagrams it appears there are 2 switches in line before the fan power... Could it be the thermal limit switch? or fan thermal limit switch?
  • 6,784 Answers
F-3
HI, This is a Open oven temperature sensor, The oven temperature sensor resistance exceeds 2900 ohms during bake, broil or clean
The sensor will need to be replaced asap. Once replaced, the error code will reset. This could be a loose connection between the control board and actual sensor. I would check the connections for proper fit before replacing the sensor.
Posted on Oct 06, 2009
Testimonial: "answer was helpful, already checked those recommendations. "
Oven beeps and show F1 and F3 while trying to cook or even 2hrs after cooking.
F1 code is a "EOC (Electronic Oven Control) failure" Replace your oven control
F3 code is a bad oven sensor the sensor should have a ohm reading of 1100 at room temp. Replace your oven sensor as well.
Dec 06, 2010 | Frigidaire 30" Built-In Single Electric...
F3 fault code on fisher & paykel wall oven.
hELLO THERE:
on these ovens the f-3 can sometime be incorporated with the f-4 error code also so here is the code and the things to look for both ok ?
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Jul 14, 2010 | Fisher and Paykel Ovens
GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Kenmore wall oven keeps showing error codes f5 and f3. Unit will not say on.
oven went into E2 F3 oven code while cooking a chicken and broil burner came on turned off oven but broil burner stayed lit, then had to unplug
Nov 13, 2009 | Kenmore 47702 / 47704 / 47709 Electric...
We have a gas maytag gas wall oven that is getting f3 and f5 error codes
F3
Shorted or open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
F5
Watchdog and hardware conflict
Replace clock (ERC).
Jul 17, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
F3 and f5 error codes on maytag gas wall oven
(((F-3)))
This is a Shorted or open oven temperature sensor (RTD). Check the following.
(((F-5)))
This is a Watchdog and hardware conflict.
This is not repairable. you will need to replace the control board or (erc)-(clock)
Feb 24, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Ovens Logo
265 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
