Question about Dell E173FP 17" LCD Flat Panel Monitor
How can i open the case to see what the problem is
My monitor turns on and off and i dont know what the problem is have tried a lot of things like removing the data cable and just using the power cord and the same result changed the power cord same results
I think, it's bad backlight. you need to replace the backlight or the lcd.
Posted on Jan 12, 2008
How to open the front pannel on this monitor
Has to be pried open and no way getting around that. Of course, if you want to use plastic explosives you are free to do so.
Aug 22, 2017 | LG W1946S 19 inch LCD Monitor
SVA VR-17s, I inadvertantly reversed the 12v power. I plugged it in and heard a snap! That was all she wrote. Can I replace a diode or other component?
It difficult to say what thing or things got damaged when they are reversed biased. If you are lucky it could just be a fuse, otherwise there could be a lot of components that could be damaged by the reversal. Only way to know the extend of the damage is to pop open the case and look inside. I would check if it has a fuse first and the condition of it and look for any obvious parts that were blown up. Unless you know how to troubleshoot electronics, it not worth the trouble to try to see if you can fix it considering how affordable LCD monitors have gotten.
Apr 21, 2011 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Compaq FS7600 Monitor adjust menu stuck onscreen and all adjustments turn to highest settings
Sounds like a button is stuck.
And other people are having the same problem.
One thing you could try is turn the monitor off, press all the buttons at once and turn it back on while holding the buttons in. This might error out the problem. though if it does make the menu go away, the next time you start it up the problem will be back.
the best way to troubleshoot would be to open the casing and test the front buttons for shorts.
I do not recommend opening the casing unless you know what you are doing, as this is an older crt and will have very high voltage internals.
Do not pay anyone to fix this for you as you can find decent used lcd's for good prices now days.
Let me know how this goes.
Mar 10, 2010 | HP Computers & Internet
My laptop got automicaly turn up after 1hrs 30
hey possible reason is your memory, try to increase your memory, or your pc have lots of worms on it, so make sure you clean up your pc, and also on the software that you installed, try to uninstall things you dont need.
Nov 02, 2009 | Samsung 997DF 19" CRT Monitor
I installed a new video card in my system. I am not getting any picture on my screen. I contacted dell and it was determend that I might need some assistance from you. can you help
Hi there ok you can try this first turn off the computer unplug the powercord from the computer , remove the monitor cable then open the case, remove the card and ensure that the slot is free of any debris canned air works good for this now now press the card back into the slot firmly and dont forget to put the screw back in if it has one now find the powersupply cable that hooks into the motherboard and unplug it and wait about 10 seconds now press the power on button on the front for 5 seconds this will clear the system now put the connector back into the motherboard and ensure that all of the cables are firmly into place hook up the monitor cable back up and put the power cord back into the computer and turn on the monitor and turn on the computer and see what happnes ok this should help if not let me know there is still things we can check ok best regards mike
Feb 16, 2009 | X2Gen MG19MY 19" LCD Monitor
Blinking Orange LED light on E151FP monitor
This monitor is know for a lot of parts that go bad, luckily they are usually the same ones.
If you are a technician or know one who can help you. Below is a list of part to repair/replace once the case is opened. (dont try this if your unfamilier with working on electronics.
1) F601= 2A Fuse
2) C605= 68uf 400v (must change)
3) R615= 0.68ohm 1watt
4) Q601= SSS6N60A
5) R613= 1Kohm 1/8watt (value changed to 2.3Kohm or higher)
6) R623= 4.7ohm 1/8watt (value changed to 7.2ohm or higher)
7) D604= 1N4148
8) IC601=UC3842B
9) C707 & C703= 1000uF 16V (must change, because of bad ESR value) secondary filter capacitor.
This problem of dell e151fp lcd monitor, you just need to resolder the inverter section (bad points or dry joint) and also check the capacitor value with ESR meter. It will solve your problems.
Sep 14, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Monitor says no signal
this could be a multitude of things. Firstly, check the connections from your computer to your monitor, unplug them and plug them back in, make sure the thumb screws that connect your monitor to your computer and nice and tight but dont use a tool to tighten them, hand tight is good enough.
If that doesnt work, then check that your graphics car hasnt been unseated from its slot, TURN OFF THE POWER to your pc, open the case and look at the graphics card inside. Push it straight back against the slot and that might help.Try connecting the monitor to another computer, although I dont think its a monitor problem. or borrow a monitor from another computer and try it. If that doesnt help then you can try a different graphics card, if you dont have one they are readily available from most major electorincs stores, or even most supermarkets with an electronics dept. Now if you do all this and it doesnt fix it then you will need to find a tech to have a look at it, Like I said at the beggining it could be a multitude of sins, a hardware error stopping the computer from booting and that requires a little technical knowledge
Aug 12, 2008 | Northgate (STAX2517C2) PC Desktop
Color turned gren on moniter
dear,
its can be ur vga cable fault, the cable that connects the monitor to Vga of cpu... so check ur cable..if faulty then repair or change it..
2ndry, it can be the fault of guns of monitor..if u can handle but it requires a lot of care to open the monitor and there are some variables of control the RGB guns... but do it only in the case, if ur expert of repair and handling of tv, monitors, or the best is to check it by an expert...dont handle it in untarined condition..but monitor picture tube contains thousands of volt even in off condition.
regards,
salman
Jul 21, 2008 | Computers & Internet
Problem with my keyboard
Hello!
You problem is so many application programs run in services of the system, these are cause by virus attack, system specification is low. memory damage and harddrive mulfunction.
It is good if only the system is the problem you can reinstall the windows, however if the memory or the hard disk, you should replace that.
In this case , first , scan your system sith potent antivirus,
you can click this http://www.precisesecurity.com/antivirus/online-scan.htm
or try replacing the keyboard, memory. and the last is the hard disk.
If it is new hard drive then you should install the operating system on it.
best reagards, melnavz
Feb 27, 2008 | HP Compaq FP5315 15" LCD Monitor
Lcd monitor goes white
The E151FPb's seem to have a problem of this sort. After doing some research online I've found that the most common problem is a few dry solder joints on the large circuit board inside the monitor. There was also some talk of a connector suffering from heat creep that sound be connected better on the inside, but usually that would make the screen turn black if it were to become disconnected. The monitor can be opened by unscrewing all the screws on the back, there should be 6 screws you need to pull out before being able to open the case. After those, insert a thin, but strong piece of metal into the side and sort of twist/slide it along the side and it should pop open some clips and just work your way around the perimeter. After that it's just some simple and obvious screws to get to the circuit boards.
Apr 11, 2007 | Dell E153FP 15" LCD Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
87 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
