Question about HP OfficeJet 6110 All-In-One InkJet Printer
Aligning Print Cartridges for the HP officejet 6110 all in one
I have an HP officejet 6110 all in one printer that won't complete the align print cartridges function. It is stuck in that mode and won't let me print.
pagebor
  • 2785 Answers
SOURCE: HP officejet 4355 all in
send it for servicing
Posted on Apr 28, 2008
  • 25 Answers
SOURCE: HP OfficeJet 6110 xi Self Test "Align Cartridge" Failure
Hello there,
Try cleaning print cartridges from HP toolbox
or reset process
Please see note at bottom re: powering on and off
1) If you know you are going through the re-set process. Ensure there is nothing in your printer que already when you want to power on again.
2) Plug printer/scanner directly into the wall, not a power bar or UPS... Read at one point, it has something to do with the electricity (KW or Voltage or Amps) factor and power requirements to the printer/scanner. However was very technical and don't remember enough details to explain properly, sorry... Anyhow, directly into the wall.
This is what has worked for me. Got original re-set process of solution from sillygirl.
3) Disconnect all cables from printer.
4) Clean the glass on top with alcohol and cotton swabs.
5) Then go through the reset process (press # 6 while plugging the power back into the printer).
6) If you have the CD for your printer it doesn't hurt to put it in your CD carriage in case your printer is looking for files or drivers. If CD starts to go to a un-install or full re-install just cancel and leave in carriage.
7) Sometimes helps if you first plug printer in.
8) Re-boot pc before powering on printer. Once re-boot has started and PC will start to look for printer.
9) Power on printer (press # 6 while plugging the power back into the printer to re-set).
10) Watch for point where your printer icon usually appears and plug the USB into the PC.
_____________________________________
11) If this does not work then take the printer apart and clean the underside of the glass as well. Unfortunately need to go through re-set process again. May need to buy a set of screw drivers for removing the glass. They are different. (Torx)
12) In another solution it states - you must clean all the mirrors inside the scanner assembly q-tips work well (black box closed with two locks) also the lens and the delicate spaghetti-like lamp. Generally this works... Not everyone has done this part but worth a try when the printer is already open.
13) There is a black and white strip at that end of the scanner. Check to ensure the strip is there, in tact and placed correctly. This is what the scanner carriage aligns itself with.
Just so people know. I have posted solutions to this before that have worked for me. However, I really do think this comes down to a driver issue (do we all have XP, mine is actually XP Home Edition). Since HP no longer updates these printers not sure if we will ever see a driver that works perfectly. Once you get it going again it will all work great. The problem lies in powering on and off. Once you get it going without the scanner carriage jamming, leave it on! Even in the case of a power out I usually have to re-set again but can get it going, eventually (it can be very frustrating). Sometimes need to re-boot PC and plug USB into the PC while booting up and just about to look for your printer. This is to ensure it finds the printer/scanner. Also, when really desperate uninstall and re-install the hardware. Sometimes can try for quite some time to get it working again and eventually have to just leave it off for a few days then can get going again afterwards. Not sure if this has something to do with memory.
Posted on Feb 28, 2009
POCBM
  • 121 Answers
SOURCE: hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Posted on Apr 03, 2009
efs_perpends
  • 1996 Answers
SOURCE: aligning cartridges, please wait
Pressed ok more than once to start alignment??
Have you worked through this page already? And you tried the "Bypassing the print cartridge alignment" solution? See HP's solution here. Make sure you don't have photo paper or colored paper in the input tray when aligning...
When you perform the reset, did you unplug the data cable (usb) as well as the power, and wait a few minutes? Try leaving both data and power cables unplugged for 1/2 hour and then resetting, and make sure you complete the power cycle by pressing start copy color. Link here.
If none of these steps work, try removing and reinstalling the cartridges, and if that doesn't help, here's a last ditch fix that may work in your case.
Otherwise, I'm afraid service is the answer...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 23, 2009
thinksourav
  • 30 Answers
take out the cartridges from the printer and then clean the contact points on the back of the cartridges with a clean piece of cloth. then unplug the power cable from the back of the printer and then press and hold down the # and 6 button from the front panel of the printer and then while pressing them down plug back the power cable back into the printer.
then insert the cartridges into the printer one by one and then the printer will start align the cartridges automatically.
Posted on Nov 04, 2009
I recently replaced my printer cartridges in my hp psc 2210 all-in-one and it printed fine the first day. Now all it will do is print the alignment sheets and won't let me copy anything. The...
alighment not sucessfully completed because of one of the catridge nozzles are clogged or carriage assm not reading the align page properly,check the align page is properly printed? if no repalce catridge, if print quality is good clean align reader which was located beside of the carriage... best of luck
Sep 07, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How do I change the ink in hp officejet 5510
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access doorc00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridgec00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tapec00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridgec00034769.jpg
  5. Close the print-carriage access door.
Back to top Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Feb 08, 2011 | HP Officejet 5510 All-In-One Thermal...
With an hp7555 printer, getting an aligning printer message that does not go away.
print an alighnment page there might be a problem with printer alighnment.
once it is complete you will not get the message.
Jan 01, 2011 | HP OfficeJet 6110 All-In-One InkJet...
After installing new ink cartridge. my multi purpose offic jet 6110 keeps saying "failed to align cartridges" though the cartridges seem to be installed properly. any ideas?
HI
try removing all the cartridges and restart the printer ,it will ask to install the cartridges,install them one by one and then see if it prints an alignment sheet,if it doesnt print it this way there is an option to align print cartridges in the printer drivers, goto the control panel--->printers and faxes--->rt click the printer icon and goto properties,under properties there should be an option for either maintenance or service this device button,when you click it ,it gives an option fro aligning the cartrdiges,
Jul 14, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My printer wont print it keeps saying press enter to alein cartridge
I just noticed in the link to your forum item that additional text appears that does not appear in the item itself. It looks like you are getting a message telling you to press Enter to align your print carriage. This is a common step after you replace an ink cartridge. According to HP.com, here's what you are supposed to do:
"A message will appear in the front panel display requesting that the ink cartridges be aligned. Press Enter to start the cartridge alignment. Two pages will print. Following the instructions printed on the second page, place the first page on the scanner glass in the lower-right corner and then press Enter to finish aligning the cartridges. Remove the page from the scanner glass when complete".
The link to those instructions is as follows:
Replace the Print Cartridge
Just follow the instructions I posted above in italics and you should be good to go. Good luck.
Oct 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
How do you change an ink cartridge on a HP officejet 5510 printer?
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
Aug 11, 2008 | Office Equipment & Supplies
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
Froze on Aligning Print Cartridges...
hmmm..defective sensor???
try this..put the old print cartridges back in and see it does same thing..
check your computers warranty here FREE
Feb 27, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Aligning printer heads
Same problem with my printer, called tech guy charged 100 bucks for nothing. Actually changed the cartridges. All cartridges have to be new and check the date on the cartridges, if installing 2006 cartridges, just use all of the same date , if using 2007 just use that date. It should work fine after that.
Jan 23, 2008 | HP OfficeJet 9130 All-In-One Thermal...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
337 people viewed this question
Seeker5211
Seeker5211
