Question about Whirlpool Dishwashers
Dishes are not dry after cycle is finished - Whirlpool Dishwashers
  • 6,784 Answers
Hi. i would test the element first. this will be the likely issue.
First, open the door
and look into the tub and locate the heating element (if it is covered, remove the lower dish rack and cover). The heating element has two terminals which extend through the bottom of the tub, note the general location where they go through.
To access the heating element's wiring, remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
Look into the lower access area and locate where the terminals come through the tub. Each terminal has a wire connected to it. Label the wires and the terminals so that they can be properly reconnected. Pull the wire off of each terminal; they are connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. Test the resistance of the heating element using a multimeter. Set the multimeter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading will be somewhere between infinity and zero. The exact reading differs by manufacturer and model. If the indicator does not move (infinite resistance) or moves to the other extreme of the scale (zero resistance) then the element is damaged and should be replaced.
Posted on Oct 06, 2009
  • Michael Masters
    Michael Masters Oct 06, 2009
    If your model is equipped with a drying fan, i would inspect it for faults as well.
    To access the drying fan, remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
    Note the location of the fan hood inside the dishwasher's tub (usually back right or left) and you will find the dryer fan beneath it in the access area. The fan motor has two wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
    Use a multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of zero.
    If the fan fails this test, it should be replaced.
  • 120 Answers
The dishes will not be bone dry after a run, they need some time to drip down and dry and the hot moist air need to disapate too. After the machine is done, open the door a bit, and check back in an hour or so and they should be dry.
My indesit dishwasher is not drying when the cycle is finish
Possibly the drying /heater element is faulty. Check the machine isn't on a non drying cycle. Some machines will do the last rinse in hot water but leave the dishes to drip dry in the hot humid air after the rinse. If the dishes or water isn't hot during a rinse , I would say its the element.
Mar 21, 2017 | Indesit Dishwashers
Ld 14aw3
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
Aug 04, 2014 | LG Dishwashers
Dishes are not getting dry with my new dishwaser
sounds as though the element is bad, verify this with a Volt/ohm meter
Jun 29, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Dishwasher leaving a white film on dishes after wash/dry cycle
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
Mar 18, 2010 | Kenmore 16764 Dishwasher
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Does not seem like the dishwasher is drying like it used to. After it has gone through its entire cycle the is steam condensation on all the dishes and the inner door. Previously, at the end of cycle...
Have you run out of Rinse Aid ?
This has a large effect on drying as well as how clean the dishes come out. Rinse aid [breaks up] the water dispersion, so at the end of the final rinse, the water just falls off the dishes, takes the sediment with it. So with the heat of the final rinse, & less water left on the dishes, they dry better.
Dec 12, 2009 | Kenmore Dishwashers
Frigidaire dishwasher - no heat coming on to dry the dishes
Did you ever learn why the heat was not drying dishes? We have the same problem.
May 18, 2009 | Electrolux Frigidaire Professional Series...
The dishes don't get dry enough
I was able to fix this by using rinse during the cycle.
Nov 11, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
My Dishwasher does'nt dry my dishes.
How old is the dishwasher? Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY. Otherwise: Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away. Works for me :)
Nov 30, 2006 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwashers Logo
90 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
