Question about Maytag Performa PAV3200
I have a Maytag Performa top loader that won't stay in balance
I have a Maytag Performa top loader that I replaced the water pump on, when the bearing went out. Now I am having problems getting it to stay in balance. It is level and I have adjusted the motor housing. So what else could it be?
    President:
  • 1,304 Answers
Make sure you locking the legs,
put it in spot tilt it forward so the rear legs are off the ground about 3'' the drop it,, this should lock your back legs and take care that
Posted on Oct 06, 2009
    Problem Solver:
  • 6 Answers
I would look at the snubber gasket. Seems to be a common problem. My Maytag Performa does the same. Heres a good link for ya: http://fixitnow.com/wp/2010/10/19/maytag-performa-washer-dancing-around-and-banging-during-spin-cycle-you-need-to-replace-the-snubber-assembly-some-tips/
Posted on Feb 03, 2011
Our Maytag PAV2300AWW Performa top load washer fills with water fine, draisn fine, spins fine, but after filling with water (even on "Mini" size load) it begins to agitate and then quits completely and...
If it was the bearing it should be leaking water out the bottom! It is more than likely the water pump. The seal in the pump drops down and then makes noise. The pump should be in rear. tilt machine back remove belt then try turning the pump by hand if tight replace.
List price is about $89.99 you can find it on Ebay cheaper
Jul 05, 2014 | Maytag PAV2300 Top Load Washer
I have a Maytag Performa Top Loader PAV2200AWW it will not spin. Previously made a loud noise. Should I repair or invest in a new one?
This is a simple fix. All you need is the transmission pulley and bearing.
Here is a link to the kit you need. It is under $50.00 and should only take less then 30 minuets to fix. Also, I included a video to walk you thru the process.
Oct 13, 2012 | Maytag Performa PAV2200
Maytag Washer PAVT-1 -stops frequently on spin cycle. Finally stopped completely. Repair person replaced water pump. Problem still exists. Spin out of balance for simple loads.
you could have a short in the safety switch for the lid, Jumper that switch and see if that helps, if so Just replace the switch
Jul 06, 2011 | Maytag Performa PAV2200
Loud clicking during spin cycle = Maytag washer PAVT234AWW
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion....
Jul 19, 2009 | Maytag Performa PAV2200
My Maytag Performa has an odor problem. Please let me know how to remediate the odor. Thnanks for your help.
Odors usually come from bacteria . Assuming that is what is causeing it look fro some washing machine cleaner. The newer style front loaders have a water door seal that the bacteria can collect in and this may be your trouble. the gasket folds down some for cleaning. Ask any appliance sales person for conformation on this and how to clean - service the gasket. It its is a top loader same thing can happen but no seal to deal with that you can reach. Use a washing m,achine cleaner in it as well.
If it is comming from your water a chet with a water treatment person is what you need. Culligan or others are what I recomend.
If this helps you please rate me as high as you can, thenk you for using fix ya. .
May 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Performa top loader stopped spinning
GO TO www.repairclinic.com ENTER YOUR MODEL NUMBER AND SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 THEN LOOK FOR PART NUMBER 1042142 THIS MAY BE THE PROBLEM. IT SAYS A WORN BEARING WILL CAUSE SLOW OR NO SPIN. YOU MAY HAVE NOT NOTICED SLOW SPIN TILL NOW BUT I'D SAY CHANGE THAT AND YOU SHOULD BE GOD AGAIN GOOD LUCK
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
Leaks water on floor and spin cycle very loud
if it sounds like a boeing jet, you will need a new seal & bearing kit. This is something a technician would have to do. many "special" spanner wrenches and spring tools required
Feb 23, 2009 | Maytag PAV2300 Top Load Washer
Maytag leaks water in the spining cycle and makes a loud noice.
how old is your maytag top loader ? pump do not leak that often on maytag top loader you may need stem&seal kit &tub bearing kit
Feb 18, 2009 | Amana 3.2 cu. ft. Top-Load Washer
"jackhammer" sound coming from my washer
# Balance the load
# Level the machine
# Inspect the water pump for a blockage
# Inspect the coupling
# Inspect the transmission
# Adjust the drive belt tension
# Check the motor bearings
# Check the drum brakes
Jan 09, 2009 | Washing Machines
Washing Machines Logo
1,051 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
