Need Service manual for LTF6000FSO
Need Service manual for Frigidaire Front loading LTF6000FSO or how is the front panel removed? I have taken off the bottom 4 screws and the three screws at the dispenser. What else is there?
Also, I have removed one side of the boot (drum side)... which contains small brownish globules. Can't imagine these are washing residue. Can they be a filtering agent to keep large particles from getting to the pump?
Thanks
  • bilbo1942 Oct 06, 2009
    Thanks tooltech 75. I had already downloaded the Owner's Manual, but it wasn't helpful for this problem. The drawing may be useful.
    I have made some progress. By taking off the top, some more screws were revealed at the top of the front panel. Removing them allows the front to come free short the door seal. There is no way I'm taking that off. With some help I was able to squeeze my hand in through the bottom to access the other side of the boot and managed to get it loose. There were three coins and a button in it plus all the light brown gritty material. .. which I have saved. If someone could tell me it's filtering material, I will reuse it.
    Thanks
  • 80 Answers
See if this helps
Complete Owners Guide
or
Parts Diagram
good luck
Posted on Oct 06, 2009
How to remove front cover
Hello friend, thank you for your post!
I understand that you would like to remove the front cover on your Frigidaire washer. Your question is labeled under model ATF7000E I was able to locate the parts manual for that appliance that shows a parts breakdown inside of your washer but no instruction guide to disassemble the front panel. I hope this information helps to some degree. -Matt
Frigidaire Manual Search Results
Sep 26, 2014 | Frigidaire Affinity ATF7000E Front Load...
How to replace the start button on a frigidaire affinity dryer aeq7000ego?
There will be screws along back at the top holding the top panel. Using the appropriate screw head screw driver you will have to get these screws out, lift the top panel slightly and push out towards the front. This should disengage the panel from the notch on the main body and come out. That will get you access to the console.
For an assembly view refer to parts manual you can download from this site
Frigidaire AEQ7000EG Parts Catalog
Aug 16, 2014 | Frigidaire AEQ7000EG Affinity Series...
My frigidaire front loader will not drain
Go in there and remove the coin cup and dump the stuff out of it.
Front loader service manual
Apr 07, 2011 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
Dec 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load model ltf6000fso. does not go into the final spin. getting code e20. unscrewed the front panel from below. but do not know how to fully take the panel off so that i could see if...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 10, 2009 | Washing Machines
Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
Jul 09, 2009 | Frigidaire ATF6000ES Front Load Washer
WILL NOT SPIN OR PUMP WATER OUT
took pump out there was a wire (under wire from bra) stuck in the propeller removed it put pump back on works fine now
Nov 05, 2008 | Frigidaire ATF6000ES Front Load Washer
Front Load not spinning
The back of washer has a access panel with screws that you can remove,once removed you can check if tghe belt broke or not.
May 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Front load dryer
Remove the front panel to get to it. Once you get the front panel off it is easy to remove the drum and replace the element. First remove the top then the front then you have it.
Dec 19, 2007 | Frigidaire FEQ1442ES Electric Dryer
Washing Machines Logo
498 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
